Old 08-10-2005, 11:32 PM   #121
tom235's Avatar
Default car battery
the battery that i use is in my car that i drive to the track (2000 vw passat)
you would think that i wouldent have a problem.
it says low voltage
tom235 is offline   Reply With Quote
Old 08-11-2005, 12:24 PM   #122
syndr0me's Avatar
Trader Rating: 32 (100%+)
What's the best way to attach the temperature sensor to the packs when I'm charging them? I've noticed they're quite a bit hotter (on a temp gun) than what the temp sensor says, which makes me worried I might be getting them too hot.
Also, anything I need to change on the default profile (#1) for 3700's, other than possibly the amperage?
syndr0me is offline   Reply With Quote
Old 08-11-2005, 12:44 PM   #123
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
If it's a stick pack, just around the middle, and have the heatshrinked bit go right around the curve of the side of the pack.
Yeah, the heatshrink may provide some insulation to the sensor, and some have stripped that stuff away, but you may risk shorting it with the exposed wires.
Otherwise, it should be good within a degree or two, but if you can test with a temp gun just compare the results, and if you find it's off by 2 degrees, just take that into account when you set the cutoff temp.
I think 5mv per cell is still standard for NiMH, so 30mV is fine. I think battery matchers recommend 120 to 130 degrees cutoff for 6-packs, but quality of batteries may change that variable.
Tom235: Have you checked the voltage of the battery with a multimeter? Also clean contacts help, but I think you've made sure of that.
Have you tried the charger with the car on? (connect it only after you turn the ignition, though) The alternator will provide a bit of a voltage boost.
-=≡ Tamiya TA05 · TRF415MSX · F103R · M-03R · M-04 · M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 · OFNA LD3 Pro · Fastcats · Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 08-18-2005, 03:05 PM   #124
hey guys anybody try testing the RPM on this and then putting it on a real dyno? I am curious to see if say Motor X has 24000 and Motor Z has 25000 on the APS how those motors compare with RPM on a high end dyno. Like if you see the same 1000 or so difference in the motors.
erock1331 is offline   Reply With Quote
Old 08-28-2005, 10:27 PM   #125
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Need to buy one urgently
Anyone knows of a online shop that has them instock and can ship overseas?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 08-29-2005, 11:14 AM   #126
tom235's Avatar
Have you tried the charger with the car on? (connect it only after you turn the ignition, though) The alternator will provide a bit of a voltage boost.[/QUOTE]
I got it figured out the new lead i put on from anouther charger were to small.work fine now it a awesome charger
Old 08-29-2005, 11:15 AM   #127
tom235's Avatar
Default thanks
thanks for all your help you all are great
Old 08-29-2005, 04:51 PM   #128
danjoy25's Avatar
Just got one from EBAY and found out that a newer version with step charging is coming out Hopefully all the other function is the same as I use linear charging
Old 08-29-2005, 04:59 PM   #129
m8commando's Avatar
I have had numerous step chargers, to tell you the truth I think step charging is overrated. I sold all of them, and purchased 2 millineum pros $50 a piece on ebay, for a fraction of the cost. And I saw no performance lost. Actually I was faster than I ever was over the weekend. Most of the time when your at big races sometime or another the power goes out. If your in a middle of a step charge your screwed. so.... in my opinion! dont believe the hype.
JAF RACING / AIRTRONICS
m8commando is offline   Reply With Quote
Old 08-29-2005, 05:33 PM   #130
burgboyz's Avatar
Trader Rating: 70 (100%+)
Default aps dyno/charger
Several guys have bought the aps dyno/charger at our track and they all seem to like them fine. One guy even has two!!! he just bought 5 new packs and we'll see how this charger does with them over the next couple of months.
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
Old 08-29-2005, 08:30 PM   #131
Jam-ehz's Avatar
From what I understand, the step charge function of the APS is apparently going to be mainly by upgrade for those who know they want it, not necessarily as a retail unit, yet at least. You'd be sending the unit into Magma in Canada for them to swap the BIOS chip.
And, it's still in testing (has a big fat warning instead of a BIOS version when you boot it up), so chances are you'll still have the linear functioning one.
I have two myself, one bought, one won, and I couldn't be happier.
Old 08-29-2005, 09:37 PM   #132
Default Dyno Charge 3 Stage Charging
I have seen team drivers testing the new software since Feb. At first I sneaked a peek while they were charging and saw it displayed cools symbols that never showed on my APS. The driver just told me they were testing some new software for the charger and didn't say anymore.
I guess it's been half a year now and I'm sure they have the software fully developed and tested by now. It's good to hear they will finally release a version for us all. I'd love to have my software upgraded ASAP!
RC Robin Hood is offline   Reply With Quote
Old 08-29-2005, 10:03 PM   #133
danjoy25's Avatar
Hopefully its just a software upgrade, as I just paid for a new one and won't be happy if a new model that physical looks different and have more better function than just 3 step charging comes out next month. Can't wait to get mine though.
Old 08-30-2005, 05:36 AM   #134
Marc_05's Avatar
Trader Rating: 9 (85%+)
Getting mine at christmas, along with other stuff.
So what do ppl think of this, is the motor dyno good? Is the charger good? Because i rather spend money on this rather than buying jst a motor dyno, and just a charger.
Marc_05 is offline   Reply With Quote
Old 08-30-2005, 08:20 AM   #135
Jam-ehz's Avatar
It's just a software upgrade, it'll physically use the same screen and everything.
It's a great charger, lets me manage my Tamiya Silver-can and Sport tuned motors for our TCS, weed out the bad ones, and tells me when they're broken in too. It may not be a real dyno, but with a baseline reading I can compare them in terms of top speed and efficiency.
My batteries have improved tenfold since switching from an Intellipeak Digital, both in duration and punch, and the temp probe and dyno stand (doubles as a motor soldering stand for me ) are great additions.
APS Dyno-Charge XrayFK R/C Items: For Sale/Trade 3 07-11-2007 01:19 PM
•••APS Dyno-Charge 3-in-1 Charger Dyno••• sohlman R/C Items: For Sale/Trade 1 11-18-2006 09:38 AM
FS APS 3-in-1 dyno Charge Deltaman R/C Items: For Sale/Trade 5 11-15-2006 10:42 PM
APS Dyno-charge Pezz R/C Items: For Sale/Trade 15 01-03-2006 02:55 AM
FS - APS DYNO-CHARGE EVILGRAFX R/C Items: For Sale/Trade 17 10-27-2005 04:04 AM
