APS 3-in-1 Dyno Charge
#91
Originally posted by mr_postman
My only beef is that I wish the leads to the battery were in the front on the unit, instead of in the back, like most of the other chargers out there. Also, the leads seem a bit shorter that the other chargers that I have.
CoBroRa/TAOB
CoBroRa/TAOB
Stephen <><
#92
Originally posted by Mr. Shookie
I opened mine up and cut a little slot in the front side panal as the very front of the charger has items I didn't want to risk damaging. I had no problems by doing this and liek you said it makes it easier to use. I am about to lenthen the leads also but I have heard it is not a good idea to make them longer as it increased the resistance for the current to the cells. I haven;t had any problemms with my longer leads from my GM COmmander chargers so I think I am going to make them longer after all.
Stephen <><
Stephen <><
#93
Originally posted by tom235
was it very hard to do?do you have any pixs
TC
CoBroRa/TAOB
#94
Also Tre Leonard does soem great work on a face plate for this charger. Here is the one he did for me.
oh yea here is a link to his site.
http://www.endlessvistas.com/tres/new1/new/
#95
you don't have to unsolder any wires if you don't want to, and i saw nothing in the front of my aps that would interfer with the wires, made my cut in the left front on the panel, i use a small grinding wheel on a dremel to make the hole in the front look like the one in the back, and if you don't have a dremel or drill, you can use a file. the case is soft metel. sorry no pictures at this time.
#96
Stephen <><
#97
NO and I will take some later today as I am going to the track for practice today. If you guys are in the vecentity of SoCal come by and I can show you. Really it was easy to do the mod. I just open it up to see where I could runt he wires out, the easiest place was in the front left side, no stuff in the way. I used a drill and a bit that was just larger than the diameter of the wire and drilled two holes right next to each other than used a dremel with a very small sanding bit to smooth out the edges and connected the two holes and the wires you just have to un-solder than re-route them through the new holes and re-solder...really was easy and took about twenty minutes. Just take your time...You don;t want it to look like some nuckle head went nuts with a drill on your pretty charger.
Custom pit boards, face places, etc really look sweet and add that little extra "personality" to your pit area. I'd be afraid to even ask how much they would even cost. I know that there a lot of time that goes into painting them up, and you know what they say, "the laborer is worthy of his hire".
TC
CoBroRa/TAOB
#100
Re: aps 3-1 charger input requirement.
Originally posted by drsfly
I have a converted computer psupply. output is only 11.8v.
My 3-1 works fine for all functions except charging. Just wont do it period. Always says low voltage or something to that effect.
Anybody have an adjustable ps they could lower the voltage on and let me know if it is just my unit with a prob. My pulsar works fine off the 11.8v output.
My first one had the fuse blown on delivery. I didn't want to open it for warranty void issues.
Steve @ speed tech made good immediatly.
It seems if you have a battery hooked up to it before turning on the psupply it will blow the 15a fuse. I think it does say not to do that in the instructions--- don't remember
thx,
basement not finished
fk05 almost-- well -- started to seal the chassis so almost started!
thx,
I would recommended a quality power supply that is primary regulated at 13.8V for any RC purposes as these PSUs will output constant voltage (approx -/+ 5%) within it's rated load. Most have these have UL/CSA approval so they are much safer than trying to convert a computer PSU which is out-right DANGEROUS if not done correctly and components secured properly.
#101
A guy at my local track has made similar modifications to his Dyno-Charge in redirecting the output lead to come out at the front of this charger. It should be very easy to do, but I prefer to leave my equipment in original form and I find the leads are just the right length to work it, or maybe an inch or 2 longer would be nice.
I've had mine for a few months now and haven't had a problem with it. I've also heard people say it would be great if it can discharge, but I really don't find it necessary cause battery charging and motor testing is already a FULL-TIME job for my Dyno-Charge, actually it's doing overtime!
#102
Yup was there, I was running my Touring Car for the big race this weekend. Remember no off road practice Saturday.....@Socal.
I was the BIG FAT Guy late twenties looking goofy guy wearing a Team Br00d shirt. Green hat.
Is any of that ringing any bells.
I was sitting near the rear and against the wall.
Next time you see me come up ansd say hi.
Stephen <><
Oh that pit stuff I think total was about $120.00 but I got a big discount only becasue I bought alot all at once. Tre's is really cool to work with. If you have a really nice paint job on your car he will duplicate it to fit all your gear. Here is all he has doen for me and the prices if bought individualy
Pit Board $65
Face plate charges
Two GM Commanders $20 each
APS Dyno-Charge $20 but I got it for free as I sent him the charger to make up a template....
Novak smart tray $10
Ott light $10
Integy Zero 30 discharge tray $10
Hakko face plate $15
Hakko wrap $15
I think those are the prices but the more you do the less each one gets.
Hope this takes that sting to your wallet you are thinking there is...LOL
Stephen <><
Stephen <><
Pit Board $65
Face plate charges
Ott light $10
Hakko wrap $15
Stephen <><
I was at SoCal yesterday, runnin' my T4. If you were out there after 3:00pm, I probably "ran" into you (I'm still just an Intermetiate).
TC
CoBroRa/TAOB
TC
CoBroRa/TAOB
#103
Stephen <><
Pit Board $65
Face plate charges
Ott light $10
Hakko wrap $15
Stephen <><
Stephen <><
Pit Board $65
Face plate charges
Ott light $10
Hakko wrap $15
Stephen <><
I normallly pit about 3 or 4 tables away from the counter, on the "onroad" side. I have a big rolling tool chest and a storage box that's bungied out, on top. I pit away from the "offroad" side, so that way, no one trips over the tool chest. I normally set up two wire racks to stack all of my electric gear on, and I usually have my dvd player going, watching anime. I'm the middle-aged guy with the ponytail and glasses. I try to do SoCal on Wednesdays. On most weekends, I'll hook up with my brother and race onroad "somewhere" or "test" at Tamiya.
Next time I'm out there, I'll look you up and check out your gear. With all the stuff you've had done, that's a pretty decent price. The hardest part would be deciding what "theme" to go with. I've been into Japanese manga and anime since the late 70's.
Thanks again for the info. Good luck this weekend. Catch you later then...
TC
CoBroRa/TAOB
#104
Well my dyno charge just took a crap. I went charge a pack and none of the buttons worked. Then I noticed my temp wire had some bare wire showing where it goes into the heat shrink by the probe.
It was touching one of the battery bars. It must have shorted there. Now when I power it up all I get is a blank screen. Is there a way to reset it or will I have to send it in. Who do I contact for service? This sucks
#105
I think someone here mentioned that the fuses inside can be replaced. You might want to check that first.
