Old 09-10-2006, 01:09 AM   #211
syndr0me's Avatar
Trader Rating: 32 (100%+)
Do you have a different power supply you can try? I had that problem with both of mine, and it turned out to be an issue with the PS.
Originally Posted by MadMikeB
Hi Guys,
After fault free operations for about a year, a few weeks ago my APS blew the 15 Amp fuse due to a power supply problem.
Ever since then, it sometimes resets during charging. By reset, I mean, it starts charging, then after maybe 30 seconds or so, the charger reboots itself. Usually if I power it off then on again it is good for a few more charges, then the problem occurs again.
Since I'm in Australia, I *really* don't want to have to ship this thing back for service.
Any suggestions?
Mike
syndr0me is offline   Reply With Quote
Old 09-10-2006, 04:06 AM   #212
Mike Haynes's Avatar
One of mine started to do this, and it turned out to be a faulty connection to the plug i power it with. The connection was loose so it showed voltage, but had a hard time passing current through.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 09-10-2006, 08:14 AM   #213
BillyCaldwell's Avatar
Send a message via AIM to BillyCaldwell
Yeah already tried another ps. I will try another plug and go from there. Thanks!
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 09-12-2006, 05:53 PM   #214
Blown 20amp fuse. I noticed there are two fuses, 15 and 20amps. Is that the norm to have the two different ratings?
Maclin | VP-Pro USA
Old 09-12-2006, 10:15 PM   #215
tom235's Avatar
i blew the 20 amp fuse in mine i replaced it with a new fuse and it works great
i think it normal to have two different one my CE has 15 and a 20
tom235 is offline   Reply With Quote
Old 09-13-2006, 08:10 AM   #216
Jam-ehz's Avatar
Send a message via ICQ to Jam-ehz
One (20A) is for the leads going to your battery/motor (This was my first charger with side-by-side packs, went through QUITE a few fuses at first by not watching battery polarity - I've learned now ), the other (15A) is for the leads going to the power supply, in case of a short or blowout.. better to have a blown fuse than a fried charger
It's a great charger, well protected from human or mechanical error.
-=≡ Tamiya TA05 · TRF415MSX · F103R · M-03R · M-04 · M-05 ≡=-
-=≡ CRC Carpet Knife 3.2 · OFNA LD3 Pro · Fastcats · Spektrum ׀ווlı ≡=-
Jam-ehz is offline   Reply With Quote
Old 11-02-2006, 04:55 PM   #217
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Anybody have issues with the consistency of the rpm readings? My numbers fluctuate to a great degree. I test my motors at 5v for 10 sec. When I throw on a stocker I could get around 22,xxx rpm, but when I look at the numbers when it spins up I'll see like crazy numbers in the 30-4x,xxx range. Then when I save it I'll see a crazy reading like 39,xxx! I tried playing with the spin up setting. It was at 5 and have gone as low as 2. I cleaned the sensor and tightend it alil' it was moving a bit. Same problem.
What volt. do you guys test at and for how long?
Dasupacat1 is offline   Reply With Quote
Old 11-02-2006, 05:11 PM   #218
Make sure the contacts on the phono jack are clean, and also make sure there is no dirt on the sensor itself (small board on the stand). When they are dirty is will misread a bit.
Old 11-02-2006, 06:11 PM   #219
loopedeloop's Avatar
I've also noticed that the sensor is sensitive to the type of ambient light around where you use it.
loopedeloop is offline   Reply With Quote
Old 11-02-2006, 06:53 PM   #220
Dasupacat1's Avatar
I tried cleaning the senso. Will try cleaning the jack. Then test in well lit area.
Old 11-02-2006, 09:03 PM   #221
Jam-ehz's Avatar
I had a few times where my RPM readings doubled at some moments, then went back down.. found it was the reflector, an edge of the foil sticker had started to peel up, so it was reflecting more than just once.. CA glued the edges down flat, no probs since..
Old 11-02-2006, 09:08 PM   #222
A_Stratus's Avatar
I misplaced my sensor...does anybody have an extra to sell???
thanks,
Aaron
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 11-02-2006, 09:19 PM   #223
You need:
APS3311
http://www.buyrc.net/catalog/index.php?cPath=23
Old 11-03-2006, 09:55 AM   #224
A_Stratus's Avatar
Thanks Mike!
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
Old 11-03-2006, 10:24 AM   #225
burgboyz's Avatar
Trader Rating: 70 (100%+)
Let's compare dyno numbers. My amp draw is different(less) on my APS than on
my friends LRP. What amp draw numbers are common for your "good" stockers??
For C-DAN and TWELVES (no fans please.)
Got Droop???
Speed Passion....Speed Power....Serpent America/Desoto Racing.
burgboyz is offline   Reply With Quote
APS Dyno-Charge XrayFK R/C Items: For Sale/Trade 3 07-11-2007 01:19 PM
•••APS Dyno-Charge 3-in-1 Charger Dyno••• sohlman R/C Items: For Sale/Trade 1 11-18-2006 09:38 AM
FS APS 3-in-1 dyno Charge Deltaman R/C Items: For Sale/Trade 5 11-15-2006 10:42 PM
APS Dyno-charge Pezz R/C Items: For Sale/Trade 15 01-03-2006 02:55 AM
FS - APS DYNO-CHARGE EVILGRAFX R/C Items: For Sale/Trade 17 10-27-2005 04:04 AM
