Old 01-23-2006, 12:11 PM   #196
I think the Npower only has 10AMPs. You might need to upgrade your powersupply. I have a MuchMore Worlds Edition 20 AMP and it works great
natskiboy is offline   Reply With Quote
Old 01-23-2006, 10:09 PM   #197
tom235's Avatar
i would go with a 20 amp that would be more than fine
more power
tom235 is offline   Reply With Quote
Old 02-16-2006, 10:21 AM   #198
IslandBwoy's Avatar
How do you guys like the aps dyno for those of you that have 'em? Are they as accurate as the other 'professional' whatevers?
IslandBwoy is offline   Reply With Quote
Old 02-17-2006, 06:09 AM   #199
I have had mine for a few months now. Works great, puts a good charge in the battery. I've used the other features like RPM and Motor test a few times and they all seem to work as good as my GFX and Indi Dynov2 did. I also used the step charging a few times. I always have the temp probe on just to make sure the batteries are staying consistent. All in all I'm very happy with it and would get another one.
My only somewhat complaint is the way the buttons are but it really doesn't bother me much if any.
Hope this helps!
schdp is offline   Reply With Quote
Old 02-21-2006, 07:38 AM   #200
IslandBwoy's Avatar
Glad to hear that you like yours. I have to Pulser C2 chargers for charging and was maining going to use my APS to weed out bad cans. HOwever with everyone talking about stpe chargin i may need to reconsider although i'm sure I wont notice the difference.
Old 02-28-2006, 11:26 PM   #201
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hi Guy may i know where can i get the
APS ceremic bearing kit thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 04-29-2006, 08:19 PM   #202
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
Has anyone found the aps to be voltage sensative.... Im running 3 chargers at one time (ce ps at first now a 36 amp integy ps) and I find that when input voltage dips around 12.5v the aps goes into low supply..... Could mine be defective?????? my other chargers work fine... gfx and pulsar2....
still fishing
ALBERTO is offline   Reply With Quote
Old 04-29-2006, 09:10 PM   #203
loopedeloop's Avatar
Yeah mine does too. It even does it when running off a car battery. It goes well to start with but as soon as the battery voltage drops a little it cuts out.
Its even worse when charging ni-cds
I have the earlier version.
It drives me nuts
I think these things need a good positive power source with at least 13.5v.
Other than this I really like mine I just wish it wasnt so fussy.
loopedeloop is offline   Reply With Quote
Old 04-29-2006, 10:51 PM   #204
Mike Haynes's Avatar
It is a bit on the finiky side when voltage gets low. Best guess i have is that the charger is designed to not pull as many asmps as you are putting into you pack / motor. I guess the transformer is causing it to be finiky? I know when you have a motor pulling 20 mine only actually draws about 12amps fromt he power supply.
You could always send them an email
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 04-30-2006, 10:54 AM   #205
tom235's Avatar
i also have a older one and it does the same thing if i didn't like the charger so much it would be on ebay
Old 06-16-2006, 09:19 AM   #206
XrayFK's Avatar
I've been looking around at some chargers recently, and have found this to be a much better alternative to the Much More charger. How have peoples' APS chargers held up after a while?
XrayFK is offline   Reply With Quote
Old 06-16-2006, 05:24 PM   #207
nagatahawk's Avatar
I purchased on in december, it didn't read rpms for the motor dyno.
I sent it back twice. it still has problems.
I like the heat probe for charging 3800s,
charges 3800's cool and peaks out around 118 degrees.
my friend had an incident where he accidently hit the the side of the metal shell with the charge cable alligator clips. It shorted something inside. I wrapped my charger with clear strapping tape, to try to insulate the charger from shorting against any external electricity.
The APS appears to be sensitive,
I would go for the LRP or the Competition Pluys Pit Bull.
nagatahawk is offline   Reply With Quote
Old 06-16-2006, 08:57 PM   #208
I have had an APS dyno charge since they were released and never had any problems.
Weird.
Michael Zufelt
It's not how you stand next to your car, it's how you race your car.
http://www.dynamichobbies.com
TheZoof is offline   Reply With Quote
Old 06-18-2006, 09:14 PM   #209
MadMikeB's Avatar
Default Charger Resets
Hi Guys,
After fault free operations for about a year, a few weeks ago my APS blew the 15 Amp fuse due to a power supply problem.
Ever since then, it sometimes resets during charging. By reset, I mean, it starts charging, then after maybe 30 seconds or so, the charger reboots itself. Usually if I power it off then on again it is good for a few more charges, then the problem occurs again.
Since I'm in Australia, I *really* don't want to have to ship this thing back for service.
Any suggestions?
Mike
MadMikeB is offline   Reply With Quote
Old 09-09-2006, 11:46 PM   #210
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Is there a replaceable internal fuse? Mine now wont charge. It started giving a bad fuse or connection error.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
APS Dyno-Charge XrayFK R/C Items: For Sale/Trade 3 07-11-2007 01:19 PM
•••APS Dyno-Charge 3-in-1 Charger Dyno••• sohlman R/C Items: For Sale/Trade 1 11-18-2006 09:38 AM
FS APS 3-in-1 dyno Charge Deltaman R/C Items: For Sale/Trade 5 11-15-2006 10:42 PM
APS Dyno-charge Pezz R/C Items: For Sale/Trade 15 01-03-2006 02:55 AM
FS - APS DYNO-CHARGE EVILGRAFX R/C Items: For Sale/Trade 17 10-27-2005 04:04 AM
