Old 10-17-2005, 04:27 PM   #151
Mike Haynes's Avatar
Factory setting on step is 5,1,6 with both of mine. I think yours was turned up already.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 10-17-2005, 04:40 PM   #152
8A, 1A, 8A doesn't sound like the factory setting...
that's probably your friends setting since you have the charger borrowed...
but anyways... for Sanyo 3000s....
I would try the following
Stage 1: 6A, 2400mah, 131 degrees
Stage 2: 1A, 2500mah, 131 degrees
Stage 3: 7A, 3400mah, 131 degrees and set delta peak around 30mv for 6 cells
Just remember to discharge your batteries on a equalizer tray before using the 3 stage charging since it doesn't do delta peak detect in the first two stages of the charge process. Also remember to loop the temperature sensor as a safe guard, I've been lazy with discharging a few times and that temperature cut-off saved my batteries from overheating. THANK GOD!!!!
Give it a try and let us know how it goes
Asurada Sugo is offline   Reply With Quote
Old 10-17-2005, 05:28 PM   #153
kp-61's Avatar
Thanks guys!
I will worked on the packs tonight and post some number.. I know the batteries are old but a good comparison might help out.
Im experimenting with 2 chargers.. one with the updated software and one with the old one just to see the difference.
kp-61 is offline   Reply With Quote
Old 10-18-2005, 06:43 PM   #154
kp-61's Avatar
Hi guys,
I have started the comparison... its not complete but i converted the excell file to PDF. is there a was to attach them ?
So far the 3S gave better results...
thanks
Old 10-22-2005, 09:28 AM   #155
ali_g's Avatar
anyone compared the dyno reading to other motor checkers?
ali_g is offline   Reply With Quote
Old 10-23-2005, 09:49 PM   #156
A_Stratus's Avatar
Does anybody make custom faceplates for this charger?
Thanks,
Aaron
Team Express Motorsports
HOBBYCRAFT CANADA
Rizzo's Rides
CEFX
A_Stratus is offline   Reply With Quote
Old 10-23-2005, 10:27 PM   #157
Taz_S's Avatar
i forget who make them but i know that someone dose make them for this charger
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 10-23-2005, 10:38 PM   #158
Taz_S's Avatar
here is two i found
http://www.freewebs.com/designsbybahnatka/gallery.htm
http://www.mcmoneydesigns.com/
Old 10-23-2005, 10:48 PM   #159
Taz_S's Avatar
http://www.tresleonard.com/
one more
Old 10-28-2005, 07:14 PM   #160
ALBERTO's Avatar
Trader Rating: 23 (96%+)
Send a message via AIM to ALBERTO Send a message via Yahoo to ALBERTO
Talking
does anybody know if this charger can charge lipo cells??????
still fishing
ALBERTO is offline   Reply With Quote
Old 10-28-2005, 10:04 PM   #161
CRASH's Avatar
Trader Rating: 26 (100%+)
No it can not.
Later,
CRASH is offline   Reply With Quote
Old 12-05-2005, 01:18 AM   #162
Has anyone else tried the APS step charging, and if so what did you use the factory settings or something else?
Also, When you are checking motors with the dyno part how long do you need to run the motor for during the test?
alang is offline   Reply With Quote
Old 12-11-2005, 12:58 AM   #163
Im interested in getting this charger and I have some questions. The motor run in has a 20A maximum current draw, my power supply is only 13A, if something is binding in a motor or my lathe pulls more than 13A will that fry my power supply? Is there any way to limit the amp draw? The minimum charge rate is .5 amps, during step charging, it seems like with other chargers people set the 2nd step to .2 or .3 amps, is the .5 really too high, or is it just not much of a difference? Is the charger easy to use with the menus and stuff? The html file of the manual looks pretty bad, but if its self explanatory, then it shouldnt be a problem. If there's a problem with the rpm sensor like some have had, can you just send them the rpm sensor for repair? Is there any type of delayed start charging, like you set a timer for the charge to start? Can you change settings while charging, like charge rate and peak detection? Is there any reason that I should consider the orion advantage over this charger? The advantage has megaflex charging which I dont think I would use anyway, and I think it has the delayed start feature, it doesnt have any rpm sensor though, anything else to it?
AE Racer is offline   Reply With Quote
Old 12-11-2005, 07:54 AM   #164
Formula1fan's Avatar
Originally Posted by Taz_S
He does great work!
Formula1fan is offline   Reply With Quote
Old 12-11-2005, 11:19 AM   #165
syndr0me's Avatar
Trader Rating: 32 (100%+)
Great charger. But here's a little word of advice:
If you live somewhere that gets pretty cold, don't leave your chargers out there. They don't seem to work right once they warm up again. I've got two that are on the fritz now thanks to sitting in my car for a couple of hours before I raced.
While this is probably true of all electronics, I've done this a lot in my life, and never had a problem like this. I suppose it's time to get them upgraded to the new firmware anyway. :-(
syndr0me is offline   Reply With Quote
APS Dyno-Charge XrayFK R/C Items: For Sale/Trade 3 07-11-2007 01:19 PM
•••APS Dyno-Charge 3-in-1 Charger Dyno••• sohlman R/C Items: For Sale/Trade 1 11-18-2006 09:38 AM
FS APS 3-in-1 dyno Charge Deltaman R/C Items: For Sale/Trade 5 11-15-2006 10:42 PM
APS Dyno-charge Pezz R/C Items: For Sale/Trade 15 01-03-2006 02:55 AM
FS - APS DYNO-CHARGE EVILGRAFX R/C Items: For Sale/Trade 17 10-27-2005 04:04 AM
