Old 09-02-2005, 11:33 AM   #136
tom235's Avatar
do you guys thinkit will be worth the $50.00 and the shipping to get it upgraded
last time i sent a charger into get upgraded i ended up sending it back 3 times for them to get it right and it still isnt right
tom235 is offline   Reply With Quote
Old 09-02-2005, 02:03 PM   #137
tom235: What charger did you perform the upgrade on?
RC Robin Hood is offline   Reply With Quote
Old 09-02-2005, 02:08 PM   #138
loopedeloop's Avatar
I love mine but find it very sensitive to low input voltage.
If any of my packs go over 9.6V(ish) I get a "supply voltage low"
message.
This means I cant charge NiCd's with it.
Other than that its a great value charger.
loopedeloop is offline   Reply With Quote
Old 09-02-2005, 03:42 PM   #139
Neil's Avatar
Send a message via MSN to Neil
I have never had a problem with low imput votage and I charge 8 cell packs that peak over 12 volts. Get a better power supply.
Neil is offline   Reply With Quote
Old 09-04-2005, 10:48 AM   #140
CRASH's Avatar
Trader Rating: 26 (100%+)
Default Dyno Charger
Just got mine yesterday. So far so good. As for step charging I have the Orion Advantage. I can not tell a difference between step charging and linear charging. Both feel the same to me.
Anyway I bought this unit mainly for breaking in and tuning motors based on the fact it can also power and /or charge my comm lathe so my orions can just charge my packs.
I noticed that the default voltage for motor check is 3V, what do most dynos actually test at voltage wise and what is everyone using default or other?
Thanks,
CRASH is offline   Reply With Quote
Old 09-10-2005, 10:33 AM   #141
Taz_S's Avatar
got mine and love it so far.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 09-10-2005, 11:05 AM   #142
tom235's Avatar
its the reedy quasar pro
CRASH i'm checking mine at 3v most dyno tuned motors are done at 5v im pretty sure
Old 09-10-2005, 11:13 AM   #143
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Thought about getting one of these. Anybody know of a place with a good price for it?
Dasupacat1 is offline   Reply With Quote
Old 09-10-2005, 12:43 PM   #144
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.speedtechrc.com/store/ebp...nid=59&id=4707. Looks like the price mysteriously went up $30 recently. Presumably because it's a new step-charge version.
syndr0me is offline   Reply With Quote
Old 09-28-2005, 01:59 PM   #145
CRASH's Avatar
Default Step Charging
Just got my new S3's today and will have my new cells this weekend. I will try out the step charging and see how well it works and report back.
Later,
Old 09-28-2005, 05:10 PM   #146
Dasupacat1's Avatar
Hey guys. Just gt my APS...one Question though when using the motor checker. Is having a high amp draw a good or a bad thing? I have several Monster Stocks that I want to check out. Just want to know what to look for.
Old 09-28-2005, 06:57 PM   #147
CRASH's Avatar
Default Stock Motor AMP Draw
A higher amp draw is definetly a good thing when it comes to a stock motor. You should see around 10amps for a good stock motor.
Hope this helps,
Old 10-11-2005, 10:46 PM   #148
tom235's Avatar
Hope this helps,
how are you getting 10 amps out of a stock motor
Old 10-12-2005, 12:10 AM   #149
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
IMHO
higher amp draw may mean something or not a thing at all,
bushings are a bit tight = higher amp draw
springs have high tension = high amp draw
superb stock motor = high amp draw
i have tuned fast stockers with low and high amp draws.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 10-17-2005, 04:10 PM   #150
kp-61's Avatar
Hi,
Just wanted to know what is a good setting for the updated software to charge an old sanyo 3000. Im not sure what the Step charge can do to fix the battery. I see that you can setup the 3 steps at different Amp, mAH and peak.
The factory settings was 8amp, 1 amp, then 8amp. Just worried it will fry the packs
I just borrowed one of this chargers to try to revive my old 3000 for practice.
Thanks in advance!
kp-61 is offline   Reply With Quote
APS Dyno-Charge XrayFK R/C Items: For Sale/Trade 3 07-11-2007 01:19 PM
•••APS Dyno-Charge 3-in-1 Charger Dyno••• sohlman R/C Items: For Sale/Trade 1 11-18-2006 09:38 AM
FS APS 3-in-1 dyno Charge Deltaman R/C Items: For Sale/Trade 5 11-15-2006 10:42 PM
APS Dyno-charge Pezz R/C Items: For Sale/Trade 15 01-03-2006 02:55 AM
FS - APS DYNO-CHARGE EVILGRAFX R/C Items: For Sale/Trade 17 10-27-2005 04:04 AM
