Much-More Power Master 20A - HELP >
Old 01-26-2005, 03:30 AM
MKH
Default Much-More Power Master 20A - HELP
Hi, I just recently purchased a Much-More Power Master 20A power supply from Hong Kong. When I used it the first time with my CS Space charger PRO, the charger cut-off after 5 min... I opened the power supply and found out that the cooling fan plug wasn't loose. Another try....... same results - This time the power supply made a squeaking/buzzing noise. I then tried without peak detection (only temperature cut-off) and this time the charger didn't stop, but after 10-15 min. the power supply again started this very annoying squeaking/buzzing noise. The noise stopped every time I paused the charger?!? I can't located the noise, but I think it's coming from one of the spools!? (I'm not that much into electronics).
Have any of you any idea why my power supply makes this noise?? Any suggestion on how to correct it??
Thanks in advance.
Michael
MKH is offline
Old 01-26-2005, 04:19 AM
We have sold quite some Much More power supplies locally and not even one customer had any problem. I suggest you contact the hobby shop from where you bought it, since it is definitely not normal
dhiracing.com is offline
Old 01-26-2005, 04:22 AM
A friend of mine has the same problem, no idea what is is though.
Sometimes the sound disappears for a while and than it is back again.
vassago is offline
Old 01-26-2005, 04:40 AM
Have you tried using another charger? Just to be sure the problem is from the power supply
Old 01-26-2005, 04:48 AM
Trader Rating: 55 (100%+)
with buying it through hk i think the power master will be set for ~240v power input, could that be the issue with you being in eu?
tones is offline
Old 01-26-2005, 05:06 AM
MKH
Post
Dhiracing.com: I've just purchased the new Team Orion Advantage charger, but I haven't received yet - hopefully I get it within 2 weeks , so 'no' I haven't tried it with another charger, however the sound is coming from the power supply.
Had I known that I could have purchase the power supply from you in Malta, I wouldn't have purchased it in HK
Vassago: Nice to know that it has been seen before. Is your friend's power supply working normally (except from the noise)??
Tones: I searched the forum for treads about the Much-More Power Master yesterday, so I've checked my power supply - it's operation on 220V as it should, but THX
MKH is offline
Old 01-26-2005, 05:59 AM
Yes, the PSU is operating normally. It's just the noise
vassago is offline
Old 01-26-2005, 09:16 AM
Regional Moderator
daniz24's Avatar
Maybe it's the fan going on and off... The cell master also has annoying fan noise you know
daniz24 is offline
Old 01-26-2005, 09:27 AM
iamramos's Avatar
I have a motor master that overheats in 10 seconds. Seems that I''m not the only one with problems as I was told
iamramos is offline
Old 02-01-2005, 10:01 AM
speedxl's Avatar
I have one with the same problem it shuts of after 10 or 15 seconds with a mod being broken in at 2 volts.
Supposivly they solved the problem.
I'd like to know who the US importer is?
speedxl is offline
Old 02-01-2005, 01:34 PM
speedxl
Rain City RC-Raceway and Hobbies will carry Team MuchMore products and will be the US Distributor
http://www.raincityraceway.com
See the Much More Cell Master thread for more info
LeadFoot is offline
