Old 01-25-2005, 09:33 PM   #1
Default Soldering specifics...
Gang-
When you are replacing wires on a speedo, such as a GTX from Novak, what settings, wattage, etc, etc... do you use?
Along that same line, and I realize it has been discussed on different threads at different times, but what irons do you guys use for wiring needs? How about battery assembly needs?
Any help/input will be greatly appreciated.
Thanks,
Joe
out_to_lunch is offline   Reply With Quote
Old 01-25-2005, 09:49 PM   #2
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Joe- you could do a search and find the answers, but I'll give them to ya short and sweet-
Hako 936 with the optional wide chisel tip. Period End of discussion.
Here's where to buy it the cheapest on the net (far as I know)-
www.kiesub.com
For batteries turn it wide ass open.
For regular stuff like batt wires and motor put it on like 5-600 deg F
BigDogRacing is offline   Reply With Quote
Old 01-25-2005, 10:08 PM   #3
Big Dog-
Thanks. I had gone back and found one thread on soldering "guns" but wasn't interested in going back, back, back, back... beyond 6 or 7 pages into RCTech.net.
Thanks. I will be ordering one tomorrow.
Joe
Old 01-25-2005, 10:31 PM   #4
NP bro. I just got a new 936 at work (Batteries Plus) from Kiesub and it's awesome. They don't make the white version any longer...
Old 01-26-2005, 12:19 PM   #5
edseb's Avatar
The reason you want it HOT, is that batteries and elecctronics don't like heat, so when you turn it up, the solder melts fast and the tip is only on the parts a minimal time. If it doesn't flow right away, and the tip is hot, make sure its clean and the solder is new. Also, you don't want the joint to be a "cold" solder, but rather have the sodler flow and make a strong joint. Hako all the way.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 01-26-2005, 12:23 PM   #6
Chris Tosolini is offline   Reply With Quote
new to soldering windsurf17 Rookie Zone 32 04-30-2008 05:05 PM
Soldering ESC - need help jgroenhof Electric Off-Road 9 01-18-2007 11:38 AM
Soldering AZNracerx1989 Rookie Zone 22 08-05-2005 09:51 PM
soldering? SPC Racer Electric On-Road 13 10-02-2004 05:46 PM
Soldering Help RubbyT Electric On-Road 15 02-22-2002 09:46 PM
