Record Breaker Charger / FrontLine2 Charger >
Old 01-26-2005, 12:48 AM
  #31
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Busted
sorry guys.. my scanner took a big fat crap tonight and it died. i wont be able to scan the manuals.
sorry again guys.
btw.. my race packs charged up to 4500mah tonight. finished 2nd in the a-main of stock. qualified 5th out of 7th.
oh ya.. TQ got away.... and at socal.. once you get away, as long as you dont make mistakes..race is over. charger worked great! sure glad i got mine. thanks again steve
Hebiki is offline
Old 01-26-2005, 01:02 AM
  #32
Originally posted by Gearhead3
This is a great charger!!!!
what so great about it? does it make coffee?
jocktheglide is offline
Old 01-26-2005, 01:07 AM
  #33
PMR
What's the difference between a front line and a breaker?
PMR is offline
Old 01-26-2005, 01:14 AM
  #34
B&O
B&O's Avatar
Frontline Version is a 4ED charger with 3 stage charging
Recorder Breaker is a 3 stage charger (manual)
B&O is offline
Old 01-26-2005, 01:36 AM
  #35
B&O
B&O's Avatar
Record Breaker is a total manual adjustable charger, people overall comments is the pack is charge a little bit more than with other charger...
Front Line Ver. 2 has three different charge mode for 3 stage charge and 4ED. It has Impact, Static, and Linear charge mode... and it has little more enhanced version of the 3 stage charging
B&O is offline
Old 01-26-2005, 01:48 AM
  #36
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
It might I think that it would be version 1.1SB
-Dave
JDM_DOHC_SiR is offline
Old 01-26-2005, 04:12 AM
  #37
Originally posted by Kenneth Tan
Did any of you guys actually get the discharge numbers off a pack after they are charged with 3/4 phase charging? Are the numbers better compared to those that are charged by linear charging?
Packs may generaly indicate a higher charge in capacity with the use of an RB
but that did not mean they had a greater discharge capacity. In most cases batteries showed a
slightly lower gain in negative internal resistane which translated in more rip or punch for the pack.
This test was done charging with a Futaba vs RB and then discharge on the Futaba.
MDawson is offline
Old 01-26-2005, 10:27 AM
  #38
esmie's Avatar
As far as I know, if charging capacity will be increasing, discharge
capacity will be also increasing a little bit. (Capacity increase for
discharge is not much greater than the one for charge.)
Therefore, we cannot expect "greater" discharge capacity, but
discharge capacity will be increasing!
This means, we can expect more run time.
Talking about "battery punch", we can give more punch by changing charge profile of RB or FLver2.
Mark, I also recommend you to test it by Fortress.
esmie is offline
Old 01-26-2005, 10:33 AM
  #39
esmie's Avatar
RB & FL Charger will be upgradable! We can always use latest information and latest ver. if user wants. I think this is one of great feedback to RB & FL users. In other words, I have never heard that other charger manufacturer provide upgrade service.
esmie is offline
Old 01-26-2005, 10:34 AM
  #40
ChrisP's Avatar
CE has been doing the upgrades for years....
ChrisP is offline
Old 01-26-2005, 10:42 AM
  #41
esmie's Avatar
How often?
esmie is offline
Old 01-26-2005, 10:53 AM
  #42
I have the same results using the CE to discharge packs as well. The charger has good results.
I like the dataset that can be generated by the Fortress but wish there was a way to add lifetime charge data to that program as well that can be manually inputted over time.
Esmie, do you work for Straight?
MDawson is offline
Old 01-26-2005, 10:54 AM
  #43
.[/B]
MDawson is offline
Old 01-26-2005, 11:00 AM
  #44
esmie's Avatar
No. I am not working Straight. Co.
I have been using RB more than 1 years & I just like it.
esmie is offline
Old 01-26-2005, 11:05 AM
  #45
esmie's Avatar
Mark, you got PM
esmie is offline
