View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#8807
Attachment 1288202
Attachment 1288203
Attachment 1288204
Mcallister released a 1966 chevelle 9''inch wide stocker body its a new release.Its one of the best looking bodies I have seen in a long while with very nice decals that come with it. would the 66 chevelle body be allowed in vta racing? it would be a very cool looking vta race car if it was.
Attachment 1288203
Attachment 1288204
#8808
Attachment 1288202
Attachment 1288203
Attachment 1288204
Attachment 1288203
Attachment 1288204
McAllister makes a wide variety of cars. The 1966 Chevelle is part of their line of 1/10 Dirt Oval bodies.
http://mcallisterracing.com/index_files/Page801.htm
Since the Chevelle is 9 1/2 inches wide, it would be over 240mm wide. This wouldn't look very good on the average electric touring chassis, which is typically around 190mm wide when using standard touring tires. Even with VTA tires, the body would be way too wide.
The only car currently on the McAllister's Dirt Oval body page that would work on a standard touring car is the '57 Ford Bomber. McAllister also had a Chevy Bomber body, but I didn't see that listed.
You might consider contacting McAllister directly about wanting a Chevelle body that would fit a 1/10 touring car chassis. They have listened to racer requests for new VTA bodies in the past, so they might be interested in creating this body in an appropriate scale. Here is their contact info
McAllister Racing
Contact us at (928) 714-1799
e-mail [email protected]
www.mcallisterracing.com
It is possible to modify any existing body to fit any existing chassis, depending on what the end result you are trying to achieve. I've seen plenty of examples of 1/10 touring bodies mounted on monster truck chassis to varying degrees of success. I've also read where people have taken wider bodies and cut them down the middle to fit on narrower cars.
Older wide pan car chassis could use a 9" body, such as the AE RC10LWide. There are also newer versions of the wide onroad pan cars that would work too. Check out the Pro10: 235mm LeMans thread here on RCTECH for more info (http://www.rctech.net/forum/electric...iscussion.html). Also check out this link on McAllister for wide pan car bodies (http://mcallisterracing.com/index_files/Page755.htm)
Finally there are several companies that make dedicated dirt oval chassis, which are definately not a converted offroad vehicle. One such company is Custom Works, which is owned by Tony Stewart. Here is a link to their website (http://www.customworksrc.com)
#8811
#8814
Real timing is what you see from the Motorliser, the G force, or some other device. This is not always the same as what the end timing marks indicate. For example, my vta motor at 45 degrees of end bell timing was nearly 59 degrees on my Motorliser. With that amount of timing, it cogged badly and my car needed to be pushed to get it started. When I turned down the timing to 45 degrees real timing (around 35 degrees on the end bell) the motor ran great. Only a few of the many motors I've tested have the Motorliser and end bell timing agreed. Some motors the end bell timing is greater than the real timing, others it is less, and some OEM motors can be either way. That's why many of us try to distinguish between end bell timing and real timing from our tools (albeit either the Motorliser or G force). While I haven't worked with the G force, the reports I've seen seem to be consistent with my Motorliser results on similar motors.
#8817
Just starting VTA and putting together cars for myself and my two sons. I have noticed (as I see others have also) then three new NOVAC 25.5 motors we got seem to have the timing decal way off. My tester shows zero degrees to correspond to about "30" on the endbell on all 3 motors. On the Fantom dyno all three seemed perform best at 15 degrees actual (45 on the endbell).
#8818
#8819
F
Just starting VTA and putting together cars for myself and my two sons. I have noticed (as I see others have also) then three new NOVAC 25. The 5 motors we got seem to have the timing decal way off. My tester shows zero degrees to correspond to about "30" on the endbell on all 3 motors. On the Fantom dyno all three seemed perform best at 15 degrees actual (45 on the endbell).
#8820
Wow that is about the worse gap between end bell and "real" timing that I've head of. What motor checker are you using? Sure glad I persisted in my fight to get the usvta 45 degree end bell timing rule over turned because of that timing decal issue. Assuming your fantom dyno is the one with the flywheel, set the actual timing at 45 degrees and run again on the dyno. Then compare both power curves and see which one you like better.
