View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#8791
How long does a set of hpi vta tires last?
#8793
I run regularly on two completely different tracks, one small track with CRC carpet, and one large parking lot track with very abrasive asphalt. On the asphalt track I get about four race days on the fronts, and eight race days on the rears. On carpet the tires can last an entire season!
#8794
Awesome. Im just looking for a tire that will last for longer than a hour. I have a sakura xi sport with a 8.5 motor and when im running on ashpault i only get just about a hour out of a set of regular tc tires before i eat threw to the foam
#8797
Thanks for the direction. I figured that with the added rubber and the off road style foam i might get a little more life out of them
#8798
Totally agree. You should try belted tires. Tamiya and HPI used to make some good belted tires, not sure if that is still the case or not. You might try looking there. If you are looking for a cheap tire that might work, you could always try the Ride tires that are the USGT spec tire. They might work if you are just bashing around with your 8.5. They are quite hard and last for a long time running them in USGT with 21.5 motors.
#8802
I was up watching racing at our local track, it was dirt, now carpet. They were running VTA today, looks like great fun. I had the LHS order me a TC6.2 for VTA, can't wait!!
#8803
I started at real 30* and worked my way up through the timing, to find the best numbers for each motor.
I would be curious to test other racers motors, to find numbers/gearing that works for them. (start a data base)
#8804
I got the SkyRC version and I went through my motors to get the "real" timing, than looked to find the Most RPM/KV without spiking the Amp draw.
#8805
