View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
89.99?
I would definitely look into the Sakura S64. Great car for the money, and parts are more readily available than some of the other econo racers. The only things I would suggest buying with it are softer rear springs, and aluminum hexes (I run 6mm front and 5mm rear). Integy has the kit for $89.99 IIRC.
if you need weight you might consider the left side of the car between motor & servo. And if you don't mind spending a little money try a 4 wheel scale.
I'm currently running a Tamiya TT-02s (with upgrades) in VTA. I am using oil filled gear diffs with 500,000 diff oil in front and 3000 diff oil in rear. The car seems to lack a little forward acceleration out of the corners. Since this is the first time I've raced a car with oil-filled diffs, any advice would be appreciated.
Obviously I may need to work on my setup in other areas of the car. RIght now I'm curious to find out what other people are using for their diffs and how the different weights affect handling in VTA.
This is typical when racing on carpet. In fact, most run a spool in front rather than a diff.
Spools typically weigh 9g to 14g close to the center of rotation, while tamiya diffs weigh in between 28g to 32g with more weight farther away from the center of rotation: huge acceleration difference.....
R/C Tech Elite Member
There is more than just acceleration. If you have more turning speed you don't need as much acceleration particularly on a technical track.
I think he read it like I read it the first time through - that the weight and upgrade kit was $90 . . . which would be a ripoff since they should be $10.
How are racers mounting racer figures in their car if it’s required?
idbdoug
idbdoug
I do it both ways... I like to mount it in the car, so just in case I want to run a different body
Darkside, what figurine is that?
hpi
That is a rad body!
