Old 01-24-2005, 07:43 PM   #1
loopedeloop's Avatar
Default Rollout
Hey ppl.
I was wondering what the ballpark rollout should be with the following motors:
Reedi ti 9x2
orion 12x2
atlas 13x2
atlas 23t
I ask for rollout as gearing is somewhat inaccurate, depends on tire diameter.(gear ratio will do if you give tire dia)
I run on asphalt (carpark Track ) 50(approx)mtr straight easy infield , frewer foam tires.
I use three cars :
TB Evo3 surikahn (12 and 13x2 )
yoko MR4TC Pro (9x2)
xpress pro 23t
Your help is appreciated
cheers
loopy
loopedeloop is offline   Reply With Quote
Old 01-25-2005, 07:02 AM   #2
ddesros2's Avatar
Default Re: Rollout
Originally posted by loopedeloop
Reedi ti 9x2
orion 12x2
atlas 13x2
atlas 23t
xpress pro 23t
For a wide open track like that:
In a TC, start with 21 MMPR for the 9x2, 23 MMPR for the 12x2 and the 13x2 and 28 MMPR for the 23T.
Go up or down from there depending on how hot your motor is, how much puch you have, etc..
ddesros2 is offline   Reply With Quote
Old 01-27-2005, 03:56 AM   #3
Talking
Thanks man
Old 01-29-2005, 08:49 PM   #4
Thumbs up Re: Re: Rollout
Excellent!!
I was running at least 9mm too much rollout on my 9x2.
With it at 22 mm the car is ballistic , though i think dropping to 20/21 will best suit our track.
cant wait till next raceday as I think the old yoko will outpace a few newer better cars
Thanks again
Geoff
Old 01-30-2005, 04:17 PM   #5
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
what exactly is "rollout"? someone please essplain to a noobee!
RCNitroDude999 is offline   Reply With Quote
Old 01-30-2005, 04:35 PM   #6
Merciless's Avatar
Send a message via ICQ to Merciless
Rollout is a very accurate way to gear different cars the same.
IT's the distance your tire rotates for every 1 turn your pinion makes.
So if someone says there running a 24.5mm rollout that means that for every 1 turn there motor/pinion make the tire will move 24.5mm along the ground.
Merciless is offline   Reply With Quote
Old 01-30-2005, 05:23 PM   #7
Furthur to the above , its an easy way to express gearing ,taking into account the different tire diameters available
Rollout Help treemagnet Electric On-Road 1 09-11-2008 05:33 AM
rollout 3808larry Electric On-Road 3 12-12-2006 06:28 PM
rollout pinggoy Electric On-Road 3 05-07-2006 09:27 PM
rollout what is it ptjonesus Electric On-Road 5 01-13-2004 03:52 PM
Rollout what is it for? Alvin Electric On-Road 11 01-17-2002 09:36 PM
