Old 03-16-2012, 03:48 AM   #1
Default Waterproofing Electrics
Hi All
Looking to build up a wet car for the coming outdoor season and just wondering what peoples opinions are on how to do this. After doing a bit of research i have narrowed it down to two options;
1. Pastidip for receiver and esc (then some silicone or bluetak around the sensor board on the motor)
2. A receiver box (and same option as above for the motor)
I will be running a futaba servo and understand this is reasonably well protected anyway, so will probably do nothing on this.
At the moment i am leaning towards the Palstidip option, as i feel more confident i will be able to do this well (worried about water getting into a receiver box.
Has anyone any experience of using the plastidip, does this really work or should i just go with the receiver box idea.
Any thoughts/comments/suggestions greatly appreciated
Mark
Bony85 is offline   Reply With Quote
Old 03-16-2012, 03:57 AM   #2
I always used to use baloons and then zip tie the end of it. Though depending on your esc plastidip may be a better option (allowing a heatsink to breath if esc temps are a problem).
J-PaP is offline   Reply With Quote
Old 03-16-2012, 03:57 AM   #3
Originally Posted by Bony85 View Post
Hi All
Mark
Mark,
Plastidip all the way !
One thing I would suggest is taking the sensor board out of the motor and doing that as well before re-fitting. Don't forget to do the sensor cable housing as well, otherwise you might find you get some water running down into the sensor port on either the speedo or the motor itself. If your motor has cooling holes, a little electrical tape over those holes can help too, but it's not going to stop everything.
After your run, GENTLY spin the wheels up to flush out any sitting water in the bearings etc. Do not go to full throttle, we saw a lot of wet tyres explode like this last year !
CPD Racing
chris_dono is offline   Reply With Quote
Old 03-16-2012, 04:01 AM   #4
Skiddins's Avatar
http://www.rctech.net/forum/electric...ssis-prep.html
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-16-2012, 06:35 AM   #5
I've found the connectors at the receiver to be a weak spot, with a sealed transmitter board (similar to plastidip). I used a factory waterproofed ESC from MRT back then. Current receivers and escs might feature buttons that may make things a bit harder to coard properly.
Tamiya TRF101, Corally F1 SL, 3Racing F1-09, Kyosho Mini-Z MR03, Corally SP12M, Tamiya SuperShot, Kyosho Optima Pro, Duratrax Vendetta.
Home track: http://www.amcaracing.nl
ijdod is offline   Reply With Quote
HPI Vorza Flux 1/8 E-Buggy Thread H0LESH0T Electric Off-Road 11250 10-02-2017 04:07 PM
1/8 scale off-road Electrics adrictan Singapore R/C Racers 6612 06-12-2012 06:02 PM
Setting Up A wet car - waterproofing electrics etc FLAT OUT Electric On-Road 13 03-30-2010 11:49 AM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 02:47 PM
