Old 03-15-2012, 07:55 PM   #1
BrianH28's Avatar
Default Battery
Can anyone tell me what lipo battery would be best for my touring car. Track is 100 x 50. I'm running brushless 17.5 and tekin ESC or Novak GTB. Might also run oval also with the touring car in a NasTruck class. What does the 60c stand for on the battery labels?
Corally RDX, CRC Gen-X 10 LE, Xray T4 14
KCCO
BrianH28 is offline   Reply With Quote
Old 03-15-2012, 08:51 PM   #2
Regional Moderator
CarbonJoe's Avatar
It's supposed to stand for the continuous discharge current. So, of the battery's capacity was 5000 mAh, 60C would be 300A continuous. However, once you get above about 40C, they are just marketing numbers. The solder connections and plugs can't handle that much current without melting.
Find a pack you can afford, since most of them are sourced from a small number of factories in China.
Aren't most NasTruck oval cars pan cars? Also, most oval series that I'm aware of run 1s LiPo.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-15-2012, 09:02 PM   #3
Hey there Carbon Joe,
I run at the same track as BrianH28 does, and our Nastruck rules are using our club rules,
1) any touring chassis that does not have a left side battery placement.
2) 17.5 brushless motor, 2 cell lipo
3) spec tires (Sweeps I believe)
And thank you for the explanation of the c rating. I use an Onyx 5000mah 25c lipo for our Nastruck series and it works fine for me.
VTA = 3Racing Sakura Zero S
Mini = Tamiya M-04
Off-Road = ECX Ruckus/Torment SCT
Home Track = Jeff's RC Studio,(Fort Myers, Florida)
NewRCSim is offline   Reply With Quote
Old 03-15-2012, 09:37 PM   #4
BrianH28's Avatar
Thank you for the response. See you Tuesday or Wednesday Sim.
KCCO
LiPo Battery Connectors? ejmetz Electric Off-Road 79 10-06-2010 12:09 AM
LIFEPO4 RX 6.4V BATTERY COBRARACING Nitro Off-Road 277 04-21-2010 03:01 AM
TRANSMITTER / RC -system servo, receiver, battery, charger, etc Erwin lewi Indonesia Racing 780 07-27-2009 10:42 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Intellect Battery 3800 rayhuang Electric On-Road 1166 05-30-2006 07:51 PM
