pan cars in parking lots
Anybody out there run a par car on asphalt? I'm a basher and I have this old rc10l I wat to play with but all I have is foam tires for it. Anybody know of some rubber tires I could run on it?
You might be able to find some capped tires used on concrete oval cars. Try this link... http://www.windtunnelracingproducts....acturers_id=53
the old Road Hawg tires use to do the trick for bashing - but I haven't seen any for pan cars in over 15 years.
For racing we use FOAM tires on asphalt - but you have to have a very clean, and pretty smooth surface...and if you want the best traction, after cleaning, spray the surface with several two liter bottles of ROOT BEER or GRAPE SODA to get it tacky.
w/o doing this - it's almost impossible to enjoy bashing w/ a pan car because they just spin out...
(Something else to assist is put a large wing on the rear of your car, using POD mounted wing mounts and a heavy piano wire to the wing.)
back when I first started in pan cars we used to practice with them all the time in a shopping mall parking lot with no cleaning or prep of the asphalt. Pink rears with Purple fronts seemed to be the hot ticket for low grip at the time. More recently when we have tried we couldn't get any foams to hook up any more. I'm not sure why they no longer work...but at one time it was done quite often.
[QUOTE=oeoeo327;10470687]You might be able to find some capped tires used on concrete oval cars. Try this link....windtunnelracingproducts.com/index.php?manufacturers_id=53QUOTE]
Thanks thats pretty much what I was looking for. All the rear tires are narrow, I'd like to find some wide ones. Not winder than normal just not narrow. Thanks for the link I will probably end up buying from them. Do you know if they are the sold in pairs or single tires, the price seems a little low.
pan car tires. regards
Norman2
best bet for CAP tires is John's BSR tires. John's RED Wide Rears I believe are the softest cap on the market, and I'd want SOFT on the back, maybe a blue or pink on the front.
as far as the old pink and purples working where the new ones don't. My "OLD" pinks were always in the 20-25 range on a durometer, where most of todays pinks are 30-35 (or harder)
My OLD Purples were duro @ 32-35, the newer ones range low to mid 40's. There are a lot of "SOFT" or Double (harder) compounds now.
I've tried both the soft foams and the BSR capped tires on my 235mm RC10L vintage '93. I've also tried Jack the Gripper and Liquid Gravity LG1 & 2 juice on them. Nothing seems to work. The car just does quick spins with very little throttle applied. I'm using a 905B hi down force body and a modern brush-less motor and ESC (mild wind). The surface is an outdoor basketball court painted with a reddish/orange paint. Our touring cars hook up to it good, but the pan cars have so little grip it's very frustrating. We are in Cancun Mexico so the temps are high all the time.
Two things will make you spin for starters: diff too tight and wrong tire shore rating... You will need hard front Tires(40+shore), and medium rears(38shore)...Also you need to make sure your front Tires don't wobble at all or it will make you spinout easily.... I run only twelve ball diffs in my pan cars for better smoothness... Good luck...
Handling problems
bertrandsv87,
Thanks for the comments. I've rebuilt my diff, and will see what tires I here. At the present time I have BSR Pinks on the rear and BSR Whites on the front. (Foams)
John's duro chart says the the whites are 30-35 duro and the pinks are also 30-35 so I'll go harder on the fronts. I don't have anything softer for the rear.
I do have a pair of Black fronts?
Usually blacks are used on the rear, and purple is what's good in the front. If you run soft fronts, you will need to turn your steering down a bit to compensate for the extra grip...
