Old 01-26-2005, 11:30 PM   #16
I am awaiting for BSR 1/12 Cap tires, but have to wait until Feb/April
tty_wai is offline   Reply With Quote
Old 01-26-2005, 11:50 PM   #17
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Quick question: if the BSR tires have the same rim and foam as Jacos, how are they different?
Speedo is offline   Reply With Quote
Old 01-27-2005, 01:06 AM   #18
Originally posted by Brian McGreevy
BSR's are on the Jaco rim. The foam however, while similar, is slightly different. But, a setup that works with jacos will usually work even better with BSRs. Last time I measured a wheel, it was 28 mm.
How is the foam different? I heard he purchases all of his sheets directly from Jaco.
speed2004 is offline   Reply With Quote
Old 01-27-2005, 03:22 PM   #19
Trader Rating: 34 (100%+)
oops
Monti is offline   Reply With Quote
Old 01-27-2005, 03:45 PM   #20
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Speedo,
BSR's also has thier durometer readings very well matched. This basically means that your fronts will be the exactly the same shore as your rears or very, very close (+/- 2 shore point MAX, usually 1). Along with what Monti said, they are gauranteed not to come off at the seams.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-27-2005, 08:13 PM   #21
Default 1/12 Scale Racing
I run John's BSR tires in 1/12 scale, both stock and modified. I have been doing very well with them and recommend them to all 1/12 scale drivers.
davidl is offline   Reply With Quote
Old 01-27-2005, 10:44 PM   #22
Originally posted by Monti
TTY, Just wait for the 1/12 caps when done they will be 200 times better than the old BSR caps.
Thanks for the questions guys! I hope by reading this forum people will see BSR as a strong alternative in racing tires made buy a company right he here in the United States!
-Monti- [/B]
1 more expectation about the foam, many local 12th er here used jaco and found that the foam surface are quite unbalance after few runs. It seems they did not mount the donuts to the rims in good shape.
However, I think BSR have much better quality on that.
Old 01-27-2005, 10:59 PM   #23
Hey guys, Im the new guy to the BSR team but have been rippin up the rug locally here in Nor-cal since I have been on the tires.
Can anwser any questions about the tires.
Hope to meet all the other team members at the birds. I will be pitted in the Maverick / JPH booth.
Dave
JPHRacer is offline   Reply With Quote
Old 01-27-2005, 11:13 PM   #24
Dave
Hi Dave,
I just sent you a pm. thanks for attention!
Old 01-28-2005, 05:19 AM   #25
Hey guys, be careful about the claims you make. If our shit was so bad we wouldn't be winning all the races. Think about it.
Jack Rimer is offline   Reply With Quote
Old 01-28-2005, 09:04 AM   #26
Jack, I do not intended to claim that your tires are bad at all. I feel that you have a great tire on the market and race results have proven that. I just want to provide any information about BSR tires that I can with hopes of people seeing that there is a choice. The chocie being that the two leading producers in foam tries make and build their tire here in the United States and not have them pre made and shipped here from over seas.
-Monti-
Old 01-28-2005, 10:30 AM   #27
KE4PJO's Avatar
I'll stick with T.M. tires and wheels.
"If at first you don't succeed, sky diving is not for you" Unknown
"A bad day racing is still better than a good day at work" Me
KE4PJO is offline   Reply With Quote
Old 01-28-2005, 01:52 PM   #28
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Hey Guys,
If you have any questions, I will be at the snowbirds to help represent BSR along with Monti.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-31-2005, 04:16 PM   #29
Oh, for those of you who don't know, if you're looking to get some BSR Touring or 1/12th scale tires, Team 1 RC stocks them at very good prices. Go to www.team1rc.com
USVTA Member #211
Old 02-04-2005, 05:15 PM   #30
seaball's Avatar
Send a message via Yahoo to seaball
jack rimer, poised and articulate, as usual.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Check out this site! zonerx Singapore R/C Racers 3 04-14-2007 07:51 PM
my site check it out hotwheels1 Web Links 0 06-19-2006 07:50 PM
check out this site chaos1 Monster Trucks 1 03-04-2006 07:31 PM
check out this site chaos1 Web Links 0 03-03-2006 04:47 PM
check out this site chaos1 Electric Off-Road 0 03-03-2006 04:45 PM
