Old 01-22-2005, 08:08 PM   #1
Default A Battery ?
alright im running a Team Losi XXX-S in stock foam using a monster stock and hurricane gp3300 and at my local track, i am running a 1.00 rollout just to be able to keep up, but in the last minute to minute and a half the battery falls off and stays there until the end of the race but i lose a good half to full second on my lap times. im using a integy 16x9v6 at 6amps and 20 amp discharge and novak smart tray with a .9 cut off. i was wonder if there is anything i am doing wrong or can do to correct this problem.
SPC Racer is offline   Reply With Quote
Old 01-22-2005, 08:16 PM   #2
Is the motor getting real hot? Maybe a weak cell dumping before the others?
RCevolution is offline   Reply With Quote
Old 01-22-2005, 08:30 PM   #3
im running 150-170 on the arm.
Old 01-22-2005, 08:45 PM   #4
Joel Lagace's Avatar
Not sure what roll out value that is? Is the Inches? or mm?
One of three things is wrong:
-battery back gone south
-gearing is way off(what are others running?)
-motor is crap although it would be crappy right from the start so this is unlikely your problem.
Sometimes gearing can be tricky, if u have a heavy finger you may not be able to gear the same way a smooth conservative fingered driver does.
with GP3300s you should not be dumping in any stock class. We run stock rubber and 19Tfoam and gear to our hearts delite without dumping.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 01-22-2005, 08:48 PM   #5
Bad choice of words, I just meant a weak cell that goes soft
Old 01-22-2005, 08:54 PM   #6
the roll out is in. and that is close to what everyone is running at .95, but if i run that i cant keep up and it does the same thing. in order to keep the batt. consitent thru the whole run i have to run aroung a .80 for roll out.
Old 01-22-2005, 08:59 PM   #7
fatdoggy's Avatar
R/C Tech Charter Subscriber
One battery pack or all your battery packs?
1.00 inch = 24.5mm
That rollout would be fine even on a small track.
fatdoggy is offline   Reply With Quote
Old 01-22-2005, 09:02 PM   #8
it happens to all the pack but one is worse that the others.
Old 01-22-2005, 09:13 PM   #9
Rob Mincey's Avatar
1.00 inch = 24.5mm
It's actually 25.4mm, but who's counting?
Rob
Rob Mincey is offline   Reply With Quote
Old 01-22-2005, 09:16 PM   #10
What ESC? I have never heard of dumping in stock sedan since 3000s came out, i would think that anyone running 3300s should be safe these days.
Is it possible your ESC is acting up? possibly overheating?
Is it possible your being too agressive with the throttle? perhaps not being smooth on the power delivery?
That roll out does look ok
www.rcottawa.com
Old 01-22-2005, 09:24 PM   #11
i am running a gtx and i only at full throttle down the straight away otherwise i am at half or less thru the rest of the track.
Old 01-22-2005, 09:38 PM   #12
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Is your gear train nice and free?
How many miliamps are you getting into your cells when you charge? should be more than 3700 if you are equalising your sells first.
Have you tried a different motor? Not just cut and rebrush.
crimson eagle is offline   Reply With Quote
Old 01-22-2005, 09:47 PM   #13
drive train free no i spin the tires with no motor in and they stop right away and the batteries do charge to 3600- 3700 every time and no i have not tried a new motor.
Old 01-22-2005, 09:59 PM   #14
fatdoggy's Avatar
How many runs do you have on the motor since it's last cut/re-brush?
Rob - opss..
Old 01-22-2005, 10:05 PM   #15
its been 9 runs ish with some practice runs.
tekin battery doctor 8.0 & fk05 battery brace xxblackheartxx2 Australia For Sale/Trade 0 04-02-2008 01:33 AM
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
33 Promatch 3300 NIMH battery cells and Battery Case nitro468 R/C Items: For Sale/Trade 10 08-06-2007 05:21 PM
FS: New Lipo battery 8000mah 7.4v fits in most battery trays aussiebuddha Australia For Sale/Trade 0 11-22-2006 03:23 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
