What is the best rc drift car currently?
#18
What is it that is a joke with the cyclone steering?
#19
Nope. The cyclone S is a much better chassis than the new one for drifting. You want a chassis with at least 45 degrees of steering in a drift car. The new cyclone isn't near that and the tamiya is even worse. Check out an, Mst, 3racing, yokomo, ect chassis. Way more for your money and they will progress through your advancements of drift skills and techniques.
Info. If one is dead set on the cyclone here is a link to mod the steering a bit.
http://csjunkies.com/viewtopic.php?t=1765
#20
A touring car is a touring car. Even if you put on drift wheels and even with a set up change, it can not match the drift performance of a Yokomo DRB out of the box.
If you are serious about drifting, the get a dedicated drift car for that. Learning and perfecting your drifting techniques will be so much easier.
#21
The TA03F have been considered the AE86 of the RCdrift world, Easy to set up for drifting, Japanese make/brand, and a model produced
from long ago resulting parts are not so easy to find. Engine placement is same as AE86 (under the hood)
Tamiya has now introduced the
XV-01 pro , Lay-out is similar to TA03F front motor 4wd, beltdrive to transfer power to rear. Plastic Materials may be even be
better, not as brittle. This seems a modern day TA03F Does anyone think this can replace/substitute a TA03F? Will the XV-01 be
like/considered a newly released TA03F with parts availablility and improved plastic materials & built quality?
Since Toyota GT86 is
considered a new generation AE86 in the 1:1 Automotive world, Can we look at the new XV-01 be viewed as a Toyota GT86 of the RC
world? ;-) 1:1 (both are from same Japanese maker -Toyota -) 1:10 (both are from same Japanese maker -Tamiya)
Can the XV-01 propell to this status as did the TA03F in the RCdrift world ?
What do you think Guys? ;-)
#22
I hate to throw a wrench in this whole thread, buttttttt actually I dont mind at all. Anyway the 3Racing car that was just released for drifting has big steering throw and the motor is all the way in front up between the shock tower and the bumper. Yes its still all wheel drive and its cheap at $120 with adequate parts support. I dont think you can get more drifter for less money. Downside is having to wait a couple of weeks for parts if you break something.
Edit: Add picture.
Edit: Add picture.
#23
+1 on the Sakura D3. I don't condone purchasing cheap clone knock offs but the YKM and the R31 @ $80 are a helluva value. As is they're probably crap box stock but the fact they're 100% parts compatible with the originals means you can upgrade the car with a conversion kit.
The original topic starter of this thread stated he had a Losi JRXS Type R. That car in itself is a great drift car with it's mass being low and centralized. It's similar to the TA06 which itself is a good drift car and well supported in the aftermarket. The JRXS isn't.
That's probably what counts the most, what's supported. HPI released the TC-FD then seemed to forget about it. Compared to Tamiya, who seem to discontinue things left and right, are still well supported by the aftermarket.
Just don't fool yourself into thinking the Traxxas Rally VXL is a good drifter!
#24
Suspended
Yokomo and Tamiya make the best drift cars. Personally, I prefer Yokomo because they have the biggest selection of aftermarket parts and upgrades.
#25
la migliore deriva [url = http://www.nitrotek.it/auto-rc.html] auto telecomandate [/ url] è Vanguard Subaru.Il Vanguard è uno dei nostri modelli elettrici più veloci per corsa su strada. Questo modello da corsa è alimentato da potente motore brushless KV 3300 ed é la scelta migliore per gli amanti dell’alta velocità. La vettura arriva giá costruita con tutto il necessario per partire subito.
#26
la migliore deriva [url = http://www.nitrotek.it/auto-rc.html] auto telecomandate [/url] è Vanguard Subaru.Il Vanguard è uno dei nostri modelli elettrici più veloci per corsa su strada. Questo modello da corsa è alimentato da potente motore brushless KV 3300 ed é la scelta migliore per gli amanti dell’alta velocità. La vettura arriva giá costruita con tutto il necessario per partire subito.
#27
The front motor makes the XV01 push mid-corner though, you have to be really wailing on it to need to countersteer a lot IMO. I could probably take out the gears in the front diff and drive it as a viscous coupling before I need 45 degrees of countersteer.
#28
The best drift car is the one you drive the best, not one that someone else drives best. It is all about getting the balance right and how you can control it.
#29
I don't know about the best, but i feel that the max speed technologies (MST) line is worth a visit if you have never considered one. i personally feel that my ms01 pro is the best bang for your buck... very adjustable out of the box.
