Old 01-20-2005, 08:47 AM   #1
Default carbide ball diff question
Is carbide ball same as tungsten carbide?
Is it a hard coating or the whole ball?
Actually, my question leads to : does carbide ball diff wears out eventually and need replacement or do they last "forever"?
thanks
Kasey is offline   Reply With Quote
Old 01-20-2005, 09:13 AM   #2
koabich's Avatar
Send a message via Yahoo to koabich
I cannot answer your first question.
But yes Carbide Balls will wear out. They will take longer to wear out however than normal balls. But keep in mind that while the Carbide balls will last longer, since they are harder than normal balls, you will need to replace the diff rings more often. Carbide ball are harder on diff rings!!
koabich is offline   Reply With Quote
Old 01-20-2005, 09:14 AM   #3
raving-monkey's Avatar
Send a message via MSN to raving-monkey
i found carbide to not last as long as steel...but they are smoother..
its the ceramic ones that last for ages between ball changes but ceramic ones are expensive...although they do seem pretty rough.
if your prepared to replace the balls more often then id get carbide..if not then just stick with steel, there isn't that much of a difference.
raving-monkey is offline   Reply With Quote
Old 01-20-2005, 12:04 PM   #4
Cole Trickle's Avatar
Default Re: carbide ball diff question
Yes.
I'm using tungsten carbide, and as far as I can see, they last longer than steel ones. I also find the diffs are smoother with tungsten balls, so I highly doubt I'll go back to steel balls.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 01-20-2005, 11:12 PM   #5
thanks for the info guys !!
Old 01-23-2005, 12:10 AM   #6
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Ceramic is by far the best, been using them in my 12th for a long time, they are great.
Chris.
crimson eagle is offline   Reply With Quote
Old 01-23-2005, 02:36 AM   #7
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Does the MIP kit come with Carbide balls AND rings?....or just carbide balls and steel rings?
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 01-23-2005, 08:56 AM   #8
koabich's Avatar
Hmm...never heard or carbide rings too.
Yeah, i would use the ceramics. I run them in all my cars. They may be more expensive, but you will never have to replace them. I had the same ceramic diff balls in my TC3 for 2 race seasons. They never wore out. They are $12.00 a set on the Acer bearing website.
MIP ball diff in MiniT install question TC_Tuner Micro and Mini Scales 2 09-20-2007 05:21 PM
XRAY Carbide Axial Thrust Ball Bearing flionbrian R/C Items: Wanted to Buy 0 01-09-2006 06:59 PM
1/8" Carbide Diff Ball in Bulk Packs noline Electric On-Road 9 10-16-2005 09:00 AM
fs: XRay 30501 Spring Steel Ball Diff (carbide balls & thrust) XCrash R/C Items: For Sale/Trade 6 07-20-2004 11:01 AM
Ball Diff Question???? Steevo Electric On-Road 4 10-30-2002 11:39 PM
