SMC releases IB3600 cell.
#301
Originally posted by Danny/SMC
... when you go to use it the next time place it on a tray. I really like the Duratrax 20 amp discharger or Integy 0-30 tray these are real easy to use.
I'm having trouble reconciling your recommendation to use the Zero-30 and your recommendation to bring cells to .9V... seems like the two are in conflict. Am I missing something?
#302
Use the zero-30 until the lights just go out - that's right at .9/cell.
#303
Bob: After you run the packs bring them down to .90 per cell using a discharger like the T-35. If you race the packs weekly leave them alone. If your going to store them for a few weeks put 500 seconds of charge back in the pack before storing it.
Next time you race your pack place it on a tray that will bring down each cell fairly fast like the APEX 20A/DTX 20A or Integy 0-30A. Leave it on this for a few minutes after the lights go out. Then start charging it. So far this has given good results. So far this has been working fairly well.
#304
We still have IB3600 packs in stock! 4 and 6cell packs available! Give us a call if you are in the market for new packs.... 407.834.9299
#305
So the zero 30, you have to keep an eye on it for when the lights go out? That wouldn't be a good thing for me.
I gave up on the IB's. I have tryed everything, and I get them to come around. Maybe I will try rezapping them.
Just ordered GP 3700's.
#306
I read my Zero-30 instructions again, and saw no mention of the "when the lights go out voltage"... so I assumed it was happening at zero volts.
how'd you come by this info? Voltmeter?
#307
Ummm, trial and error mostly.
I guess it's from the old lightbulb thing (minus the cutoff, which seems to cut off right when the bulbs drop down anyway)
No scientific measuring, although I probably should do that this evening. . .
but, from my old electronics classes, that's around the voltage needed to light a small bulb. . .
#308
Well, I got that batts to work. I took them yesterday, zapped them, let them sit until our race tonight and then flex charged them. Now they work great, where before they weren't even usable. Ye Ha....... I still need to try them in mod, but no one have any motor for me in stock. BTW the 3700's worked great in mod also.
#310
Danny,
How is IB3600 compared to GP3300&GP3700 in terms of voltage, run time, IR and price?
#311
More runtime than the 3300, lower IR.....voltage around the same.....price is about the same, maybe a little cheaper than 3300....
3700 more runtime, higher voltage (from the packs that I have seen), a little higher IR......and much more expensive.
Later EddieO
Later EddieO
#312
today i finally found out how intellect cells work... after all interesting numbers, i just equalized 2 unmatched IB packs, two unmatched gp 3300 packs and charged at 4 amps.
i have to say that IB packs were much more punchier and higher top speed.
now i can really say that IB cells are good.
#314
Originally posted by HVAC25000
So for racing 4wd mod, am I better off buying the IB3600s, or the stick packs of 3300s? The stick packs are $70, and the IBs are $50 (this being the point that is creating my indecision).
Thanks!
Thanks!
