Old 03-02-2005, 10:32 AM   #286
Regional Moderator
daniz24's Avatar
Maybe you has 1 cell broken/damaged. Overheat when building your packs, a bad batch, etc. If you have a Protrak, you can try to discharge and check each cell to see which one has damaged.
daniz24 is offline   Reply With Quote
Old 03-02-2005, 10:55 AM   #287
Company Representative
Danny/SMC's Avatar
The Turtleman: Are your packs matched or unmatched ? You also need to only discharge them to .90 per cell after a run. No deep discharge.
This cell is built differently than a GP cell and doesn't react like a GP cell. So far we have had good luck with traying them just prior to charging them.
Boomer: I see a few problems with unmatched cells the capacity of the cell fluctuates allot with the IB cell. This is normal because IB doesn't cycle its cells. So you can have a 405 with a 445 in the same pack. The pack will still run well but not be at its maximum potential. Another thing to note is there has been updates made to the IB cells so some of the loose cells available at a low price could of been from older batches that weren't as good as the newer ones.
We will offer a matched pack at a retail of 55.00 the cells will all be matched at 35 amps. This way the racer who wants to have great club packs or practice packs should be happy.
Danny/SMC is offline   Reply With Quote
Old 03-02-2005, 11:07 AM   #288
TheTurtleMan's Avatar
Trader Rating: 31 (100%+)
They are matched. Can you mess up these cells? I haven't done anything any different then what I would have done w/ 3300's. I have 3 4 cell packs, and right now they all suck.... should I try cyclling, or rezapping them?
CLICK HERE FOR ALL YOUR RADIO AND MORE SKINZ!!!!
http://www.rctech.net/forum/showthread.php?t=184104
WWW.BUSTOUTBMX.COM
TheTurtleMan is offline   Reply With Quote
Old 03-02-2005, 11:36 AM   #289
Danny/SMC's Avatar
Turtleman: Not sure what you can do. It seems like you were discharging them to low on your Novak tray. If you stored them lower than .90 per cell this could of hurt the cells.
Old 03-02-2005, 02:20 PM   #290
I have 5 packs unmatched IB3600's the lowest I have seen when charged is a hair under 3700mah, the highest was 4187 mah.
I have no problems running them for 5 minute 1/10 TC heats, and have made up ground at the end as a competitor's GPs were dieing where my IB's still had lots left +)
I charge at 6A 35mv peak on an APS, after the run I discharge at 30A and then use smart tray to go down to .9
MartynD is offline   Reply With Quote
Old 03-02-2005, 02:42 PM   #291
Rod M's Avatar
is that 35mv peak per pack or cell?
Rod M is offline   Reply With Quote
Old 03-02-2005, 03:47 PM   #292
Exe
Exe's Avatar
Send a message via ICQ to Exe Send a message via Yahoo to Exe
per pack i suppose
Exe is offline   Reply With Quote
Old 03-02-2005, 04:30 PM   #293
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Charge Amps
Would the same apply for this cells?(charge at 5 amps you get better runtime less voltage and at 6 amps you get less runtime but better voltage)
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-02-2005, 04:41 PM   #294
Exe
Exe's Avatar
Default Re: Charge Amps
i didn't see any runtime or voltage difference, charging at 5 or 6 amps, see the pic
Old 03-02-2005, 04:41 PM   #295
Exe
Exe's Avatar
i didn't see any runtime or voltage difference, charging at 5 or 6 amps, see the pic, light color curve is 5 amps charged pack being discharged @30amps, dark - 6 amps charge @30 discharge.
i used unmatched cells.
Old 03-02-2005, 04:49 PM   #296
danjoy25's Avatar
Default Re: Re: Charge Amps
I did see that , but I think the test should have been done with 2 packs, one charge with 5 and the other on 6 amps and cycled twice as I think you tend to get a better numbers on the 2nd cycle. I might try it once I get my virgin cells and will post next week the results.
Old 03-02-2005, 05:25 PM   #297
per pack, the APS only has per pack not per cell.
I have a Triton which only charges at 5A and the APS which I use to charge at 6A, I notice a big difference in punch between the chargers/Amperage.
I race stock and 19T so runtime isn't an issue for me
Old 03-02-2005, 10:44 PM   #298
highwayman's Avatar
If i use a novak smart tray, what cut-off setting should it be prior to charging?
thanks - jason
Originally posted by Danny/SMC
If your concerned with keeping the runtime as high as possible then using them once per day is reccomended.
Also if you plan on using them each week then storing them at .90 per cell is fine but if you plan on storing them for multiple weeks you should put back 300-500 seconds of charge in the pack. The when you go to use it the next time place it on a tray. I really like the Duratrax 20 amp discharger or Integy 0-30 tray these are real easy to use.
highwayman is offline   Reply With Quote
Old 03-02-2005, 10:50 PM   #299
danjoy25's Avatar
thanks - jason
I read .09, anything lower is not good for the cells
Old 03-03-2005, 01:24 AM   #300
Danny/SMC's Avatar
You should bring them down to .90 per cell.
IB3600 Cell - only need one or two nckmat Australia Wanted to Buy 1 09-07-2008 07:47 PM
IB3600 & GP3300 Practice Packs (4 Cell) MyRCTrader R/C Items: For Sale/Trade 5 02-01-2008 10:13 AM
*** Pro Match Racing - IB3600 6 cell packs *** raydog R/C Items: For Sale/Trade 5 07-16-2007 02:19 PM
SMC IB3600 and 3800 4-cell packs rayhuang R/C Items: For Sale/Trade 6 02-24-2006 03:56 PM
2 IB3800, 2 IB3600 and GP 4-cell packs!!! rayhuang R/C Items: For Sale/Trade 18 11-01-2005 01:43 PM
