Old 01-19-2005, 08:47 AM   #1
kidDynomite's Avatar
Default Motor Cooling Fans
I see more and more racers cooling down their motors with 25-40mm 5V fans. I was wondering if anybody has any wiring tips? Are some using dedicated micro packs or plugging straight into the receiver?
Experience wise, would it be benificial for stock & 19T?
http://www.allelectronics.com/cgi-bi...220&type=store
Thanks!
kidDynomite is offline   Reply With Quote
Old 01-19-2005, 09:17 AM   #2
Trader Rating: 69 (100%+)
the easiest route would be to plug in directly to the receiver. i stole the 5v fan from my trinity real time 2 and soldered on a receiver plug harness. im not sure if it drastically reduces motor temperatures during a run (i wasnt able to measure motor temp before and after installing a fan.)
marvi is offline   Reply With Quote
Old 01-19-2005, 11:04 AM   #3
Eric Gebhard's Avatar
I have noticed a difference in performance after I installed a fan, especially in stock. It allowed me to go up a tooth or two and not have the motor go flat at the end of the race. As far as wiring goes connecting to the receiver is probably the easiest although you could connect directly to your batteries. Allecelectronics.com is a good source for fans. I think I paid $2.00 for mine. They also sell connectors so you can wire to the receiver. Iíll try and post a picture of the fan on my Xray tonight.
Eric Gebhard is offline   Reply With Quote
Old 01-19-2005, 11:10 AM   #4
jag88's Avatar
We spend BIG bucks on batteries with great numbers and then we hook up 2 fans and digital servos to them with the hopes of going faster. Don't they draw to much juice and degrade performance ?
jag88 is offline   Reply With Quote
Old 01-19-2005, 11:29 AM   #5
The fan Iím using draws .09 amps, which is insignificant compared to current the motor is drawing.
Old 01-19-2005, 11:55 AM   #6
would i be able to hook two fans into one plug and plug it into the reciver?
SPC Racer is offline   Reply With Quote
Old 01-19-2005, 12:22 PM   #7
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
yeah, they make a splitter, you might check in the aircraft section at your LHS or tower hobbies... Y-Harness I believe is what you will find it under...
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 01-19-2005, 01:01 PM   #8
c-lyon's Avatar
I find that on my XRAY a fan reduces the temperature between 20* and 30* F, depending on the motor. Another racer with a TC4 and dual fans claims up to 40*F. I can definitely feel the difference with the finger test.
c-lyon is offline   Reply With Quote
Old 01-19-2005, 01:26 PM   #9
Thanks for your input and new questions.
So is the right type of fan to run the 5Vs and what size do you guys recommend?
Old 01-19-2005, 01:35 PM   #10
5V is what you want. As for size check Associated's website. They sell a small fans that is perfect. It works in the Team Tamale fanmount for the Xray. I'm sure they will have the spec for it on there so you can go find it on a electronics website.
NismoSkyline17 is offline   Reply With Quote
Old 01-19-2005, 01:48 PM   #11
Steve Bahnatka's Avatar
Send a message via AIM to Steve Bahnatka
team trinity makes a great fan. it mounts on top of the endbell
PN #tri13018
SMC-/-JACO-/-PARMA-/-TEKIN-/-CRI
Steve Bahnatka is offline   Reply With Quote
Old 01-19-2005, 01:51 PM   #12
I'm using a 40mm fan and it works really well.
http://www.allelectronics.com/cgi-bi...189&type=store
Old 01-19-2005, 02:00 PM   #13
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
The trinity fan is nice - if you have room for it I know its a tight fit for my electronics in my Tamiya EvoIII - So I'm thinking my fan is gonna get mounted on the top deck right over the motor and speedo
I'm running a 40mm fan - this was borrowed out of a Trinity B4 stand with fan...I swapped fans
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 01-19-2005, 02:24 PM   #14
X2
X2's Avatar
That car in the pic at the beginning of this thread has interesting wiring. Is it just me or does it have 2 switches?
X2 is offline   Reply With Quote
Old 01-19-2005, 02:27 PM   #15
It does. One is for the ESC and the second is wired to the fans so they can be turned on and off.
Brushless Motor Cooling Fans? azrael_nite Electric On-Road 3 04-29-2008 06:05 AM
Motor Cooling Fans..... RED-LINE M03 Florida Racing 2 06-25-2006 10:02 AM
Motor Cooling Fans..... RED-LINE M03 R/C Items: For Sale/Trade 7 06-23-2006 04:32 PM
Motor Cooling Fans 30mm F/S jaysimpson R/C Items: For Sale/Trade 6 08-02-2005 08:33 PM
Motor cooling fans? jwwu Electric On-Road 4 04-09-2003 05:46 PM
