Old 01-19-2005, 02:32 AM   #1
MDL
Default Charging a Ni-Mh on a Hi-CD, to get higher voltage?
Hey guys,
I have a Supernova 250s the max amps you can charge a Ni-Mh is at 3 volts. I am able to select a Ni-CD and change it at 5 volts,
Will this kill the battery? I only ask is that I have 2 Sanyo 3000 RC-3000H packs and I can't get them to take a full charge. I mean I discharge them and they will only charge up to 2500-2800.
I have a cheap 3000 Ni-Mh pack and do the same thing and it takes a 3300 charge?
So will it kill my batteries?
MDL
MDL is offline   Reply With Quote
Old 01-19-2005, 03:47 AM   #2
sosidge's Avatar
Does the charger have an adjustable peak delta? If so, you can set it to a NiMH safe level and used the NiCd charge at 5A.
I think your problem is more likely the cells - a higher charge rate won't help you get more charge in.
They are either false-peaking (i.e. still cool when the charge finishes) and need to be topped up with another charge, or they are just old and out of condition. The 3000H was Sanyo's first 3000 cell, is well short of the perfromance we get now, and didn't have a very long usable life either before capacity and voltage plummeted.
Old 01-19-2005, 04:48 AM   #3
stinkypop's Avatar
On your super nova are you using the Auto charge mode or are you selecting the (manual) start mode.
In (manual) start charge mode you can increase the amps to 5 by holding down the up button.
stinkypop is offline   Reply With Quote
Old 01-19-2005, 05:58 AM   #4
MDL
I'm using the manual start mode. Yes you can increase the voltage but not when you have Ni-MH and 3000 selected it drop's back to 3 amp max :-(
MDL
Old 01-19-2005, 09:04 AM   #5
I have some exp with this charger. It has a brain that interprets feedback from the battery during charging. It will drop the charge rate under certain conditions mainly due to battery condition. I used to set it up manualy as a 5000mAh pack so I could charge at 5amps.
Also...
Only new 3000's ever charged to the 3000 capacity. Once they were used a few times they loose heaps of capacity and some voltage. Just cheak that the batt is warm when it finishes charging. If not, you will need to restart it.
Note: on auto mode, no other charger can match this one for batt performance... tho it is its own enemy cause you don't know when your pack will be charged either!!!!
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-19-2005, 02:08 PM   #6
MDL
yeah but you can only select 5amps on the Nicd. By the sound of it, it shouldn't hurt the batteries.
MDL
Old 01-26-2005, 04:26 AM   #7
stinkypop's Avatar
you can definitely select 5amps on NIMH in start mode.
Nicd peak differently to Nimh so I woudln't use it that way.
NiCD/NiMH Voltage vs Lipo Voltage bryanleec Radio and Electronics 10 02-06-2008 06:08 PM
charging high voltage packs? joe of loath Electric On-Road 6 09-10-2007 11:56 AM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 12:40 PM
Interpreting peak voltage during charging Iceracer Electric On-Road 3 11-03-2006 12:13 PM
Matched Gp1100 2/3a Cells "higher Voltage And Lower Ir Than Trinity [email protected] R/C Items: For Sale/Trade 0 11-11-2004 06:33 PM
