Old 03-01-2012, 11:49 PM   #1
Default Gens Ace 5000 mah battery weirdness
I bought 4 of the Gens Ace 5000 mah 40c batteries in late january. Ran like 4 races on them so far. 3 of them charge on the average between 1800 and 2100 mah after a 6 minute heat race. The 4th one always charges to 5000 mah regardless.
What would cause this? Is charges to 8.5 volts and balances within 0.01 or 0.02 between the cells but always goes to 5000 mah.
Seems kind of odd...
rsscoggins is offline   Reply With Quote
Old 03-02-2012, 11:51 AM   #2
Serpent Guy's Avatar
bad cell in the pack most likely, next time you run check pack temperatures, that bad pack should be higher than to other 2
Serpent Guy is offline   Reply With Quote
