Old 03-02-2012, 05:33 AM   #16
Trader Rating: 38 (100%+)
Got brave and hooked up the ESC to a different receiver this morning. Didn't work on that one either so I think my ESC toasted as well.
or8ital is offline   Reply With Quote
Old 03-02-2012, 05:35 AM   #17
Regional Moderator
CarbonJoe's Avatar
Was this a brand new Rx, or a used one? If new, give Spektrum a call. As stated above, they have really good customer service.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 03-02-2012, 05:37 AM   #18
brand new out of the box. Plan to contact them today. Just a bummer because I was gonna race for the first time this weekend. Guess I will see if the hobby shop has a new ESC for me. Gonna have to contact Tekin too on that.
Old 03-02-2012, 05:46 AM   #19
Sorry to hear about your issues, hope it all get straightened out quickly for ya... where were you going to race at this weekend ?
The Hobby Shop,The Ohio RC Factory
T.O.P. Photon CRC XTI, XRAY T4 15 xray xb4 xb8e losi sct 2.0
insanity takes it's toll...please have exact change
bpalmer is offline   Reply With Quote
Old 03-02-2012, 08:17 AM   #20
Skiddins's Avatar
Originally Posted by CarbonJoe View Post
Of course.
While a good idea for your specific application, it more than likely voids the warranty. And that won't prevent a piece of metal from shorting the servo connector pins, since you can't conformal coat the pins otherwise they won't conduct.
You can always coat the pins you aren't going to use or just use a blank connector as a 'blocker' to protect the pins (which is basically what I do when coating it to prevent it from insulating all the pins)
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 03-02-2012, 09:26 AM   #21
One other thing concerning me is if there is a change it has something to do with the motor. The two things that were acting weird:
  • the fan attached to my speedo directly slowed down on braking but not really on throttle. I had always observed the opposite from that
  • the car was acting like it had very little brakes (tekin rs speedo)
  • this happened after braking hard (or trying to)
Indy if they are racing.
Old 03-02-2012, 09:44 AM   #22
tc3team's Avatar
A thought from me is that if the end points on the servo were not calibrated on the transmitter may cause excessive current draw, and cause a failure somewhere.
As said, servos (Savox are where ive heard the main issues) can pull a lot of current.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 03-02-2012, 09:57 AM   #23
212
Old 03-02-2012, 10:01 AM   #24
End points were set.
Old 03-02-2012, 04:20 PM   #25
Got a new servo, new receiver, borrowed ESC. Please don't be a motor issue!! Here goes nothing....
ESC and Receiver on their way back for repair.
Old 03-02-2012, 04:32 PM   #26
Regional Moderator
CarbonJoe's Avatar
Tekin? If so, before pulling full throttle, spin the motor slowly by hand to see if the 3 right most LEDs light up in succession (although very dimly). That will at least tell you if the sensor is being read. Try servo first, then just ESC. Finally, both.
1/12 forum ovalnator Electric On-Road 46184 Yesterday 09:37 AM
Fried Spectrum reciever rdcracer Nitro Off-Road 12 12-17-2008 06:51 PM
