Cyclone WCE CVDs
What are my options for CVDs? I have 1 bent rear cvd and I believe its causing vibrations at higher speeds. Its a 3racing part. I looked on 3racing's site, but they only have the universal CVDs and I'm not sure if they will fit. Any suggestions?
when I was running a cyclone you need 44mm shafts. HB makes cvds in steel an aluminum or you can opt for their DCJ shafts. Spec R and Exotek also makes steel options.
