Old 01-16-2005, 06:27 AM   #16
Timmy_G's Avatar
Send a message via MSN to Timmy_G
yes my motors run hot. hot enough that you dont want to touch them sometimes after a run.
both the kisbey modifieds are virtually brand new as of racing today.
I dont race on foams, only rubbers. I have semi agressive throttle use.
Drivetrain is perfect. Smooth as silk.
Schotty, yes i run one.
If i can check the drive frequency, I will
Thanks for you're help.
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 01-16-2005, 06:50 AM   #17
1M
1M's Avatar
Trader Rating: 35 (100%+)
Tim_Gaukroger
You posted: run a pen down each section gap to fold down the edge.
Don't do this. Clean the slots with an exacto knife and run. If you run a pen down the slots you are actually distorting the copper causing the brushes to bounce witch causes more arcing on the brush. Hope this helps.
1M is offline   Reply With Quote
Old 01-16-2005, 10:00 AM   #18
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
arcing = burnt comms - too much timing, driving style (braking, pumping the throttle) overgearing, out of round comm, poor spring tension causes arcing which may lead to overheating. if you overheat too much it burns the brushes which damages the carbon molecules. on some cases it will overheat too much and cause the brush ends to crystalize.
you can deglaze the brushes by cleaning it with a comm stick. if it is too silvery or worse bluish it must be replaced.
you can get away with slightly bruned brushes on small races and practice runs. BUT on big races you must change it and use a new pair.
REMEMBER when you use brand new brushes ALWAYS CUT THE COMM.
one more thing that you might be overlooking is that your springs may be too soft or worn out try to replace new springs. or your timing might be too high.
this is just my 2 cents. im not trying to say the other posts are wrong. just wanna help out. who knows the answer might be 2 posts combined.
S-T-R-l-K-E-R is offline   Reply With Quote
Old 01-16-2005, 10:27 AM   #19
STLNLST's Avatar
Trader Rating: 21 (100%+)
Ditto what striker said.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-16-2005, 02:37 PM   #20
Timmy_G's Avatar
thanks for the very useful info guys. I'll give the tips a shot and see how I go.
Tim
Old 01-16-2005, 03:03 PM   #21
fatbear's Avatar
Send a message via Yahoo to fatbear
Your problem is 99% probably poor spring tension. You must run really hard motor spings and run about 12-14 degrees timing.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 01-16-2005, 03:49 PM   #22
Timmy_G's Avatar
the springs on the Kisbeys are considerably soft.
The orion's I've been using std brushes which i think are medium hards.
Tim
Old 01-16-2005, 04:13 PM   #23
fatbear's Avatar
Your springs on the Kisby should be 1 down from the hardest you can get. Probably chrome coloured ones. I am not sure about the orion motors as i have never run one. The Reedy motors are better.
Old 01-16-2005, 06:16 PM   #24
dontfeelcold's Avatar
Hey Tim,
You still using a spool and braking into corners?
dontfeelcold is offline   Reply With Quote
Old 01-16-2005, 06:56 PM   #25
Timmy_G's Avatar
nar kempy i've been running the spool and no brakes since templestowe.
Old 01-17-2005, 06:47 PM   #26
the CS silver, LRP, Plutonium brushes leave a greyish silver finish on the comm after the run, its what they do. Also low wind mods a bad on the comm, fact of life.
Old 01-17-2005, 06:58 PM   #27
Timmy_G's Avatar
yea i know they leave a silver finish on the comm. but its still clearly burnt.
I expect more then 1x run from my motors before the comm is badly burnt, be is 7 8 or 9 turn.
Old 01-17-2005, 07:05 PM   #28
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Another thing to check is your armature. I am not sure what Kisbey does for balancing, but I had a motor fling some epoxy off itself during practice, and when I ran it in qualifying, it sounded kinda off and the motor got very hot and the comm very discolored. Check to make sure nothing like this has happened to your armature. But like everyone said, check your spring tension, sounds like too light. Trinity Purples should be fine. The yokomo based mod won't get more than 1 to maybe 2 runs before it needs to be cut. The V2, however, should be able to be run at least 2-3 times with sprint brushes in it. Run hard springs in the V2 motor.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 01-17-2005, 08:08 PM   #29
Trader Rating: 55 (100%+)
are you running the brushes in before you hit the track?
2 volts at low timing till they're totally seated right.
tones is offline   Reply With Quote
Old 01-21-2005, 02:39 PM   #30
Timmy_G's Avatar
yea I seat them fully with no timing.
what's the chances of the speedy i use causing my comms to burn badly? I run a Gm Sx9. Any thoughts? Are some speedys better than others.
Cheers, Tim
MOTOR COMMS 16skyline Electric On-Road 75 05-05-2007 08:02 PM
Cutting comms Still Bill Electric On-Road 16 07-09-2006 12:32 AM
COMMS serpentrush Electric On-Road 6 01-12-2006 02:48 PM
new motors and their comms onnetz Electric On-Road 18 08-28-2004 01:23 PM
Reedy Big Comms, how low can you go'? Cain Electric On-Road 2 03-09-2004 11:19 AM
