Old 02-23-2012, 11:02 AM   #1
Ariel Reds's Avatar
Default help! need some advice.
my receiver antenna wire has been cut off
i want to know, is there any negative effect? any glitch on the signal?
or i should buy a new receiver
im using m11x, 451R receiver
Team Max EP Terengganu.
Kuala Terengganu Radio Control Club.
Joy and Passion, its all about.
Ariel Reds is offline   Reply With Quote
Old 02-23-2012, 11:04 AM   #2
SteveM's Avatar
Trader Rating: 142 (100%+)
Do you have the piece that got cut off? The receiver will have reduced range unless the antenna is factory length and it's best to replace the antenna.
SteveM is online now   Reply With Quote
Old 02-23-2012, 11:08 AM   #3
Ariel Reds's Avatar
the antenna wires that remain attach to the receiver is about 2 inch left is there any way to compile the cutted wire?
Old 02-23-2012, 11:27 AM   #4
SteveM's Avatar
Send Airtronics an email and ask how long the antenna wire should be for the RX451R receiver and ask if they sell a replacement antenna.
Old 02-23-2012, 11:30 AM   #5
SteveM's Avatar
From the manual...
"The antenna is delicate, therefore, handle it with care. Do not pull on the antenna with force. Do not cut or extend the antenna."
Telephone: (714) 963-0329
Fax: (714) 964-6236
Email: [email protected]
Need some advice.. New comer here! Nation Electric On-Road 11 12-15-2009 10:56 PM
Need Some Advice Here TigerCoach Rookie Zone 31 08-29-2009 05:11 PM
New to nitro need some advice whitevomr Nitro On-Road 15 06-09-2007 02:04 AM
