Old 01-15-2005, 03:34 PM   #1
Default soldering batterys with wire?
i got some batterys today for my lathe (4 cells) but my lhs was out of the battery bars so i was wondering if i could use some deans 12g ultra wire instead because i found 2 feet of it lying around? thanks
kh15 is offline   Reply With Quote
Old 01-15-2005, 03:42 PM   #2
Jack Smash's Avatar
Trader Rating: 29 (100%+)
yeah, that would work. The batt i sent you should be there in a few days.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 01-15-2005, 03:42 PM   #3
MikeDeadly's Avatar
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Send a message via AIM to MikeDeadly
I wouldnt see why not. There would be no structural support for the pack though, which may make them more prone to short since the cells would be flopping around.
MikeDeadly is offline   Reply With Quote
Old 01-15-2005, 03:46 PM   #4
thanks guys
and mike i plan to use good old duct tape so thier will be no flopping around, i hope lol thanks \m/
Old 01-15-2005, 04:39 PM   #5
Rod M's Avatar
I have seen guys who use two solid peices of unsheilded copper wire (1mm thich) for battery bars,
Rod M is offline   Reply With Quote
Old 01-15-2005, 07:33 PM   #6
well the wire worked great i just charged it up about an hour ago so everything worked out! but my chager is telling me that its got 5.47 volts in it but for the lathe i need 4.8?
Old 01-15-2005, 09:21 PM   #7
fatdoggy's Avatar
R/C Tech Charter Subscriber
Just use a 3 cell pack then...
fatdoggy is offline   Reply With Quote
Old 01-15-2005, 11:08 PM   #8
Losi Will's Avatar
Send a message via AIM to Losi Will
5.47v is unloaded voltage. It has no bearing on performance. A four cell pack will always have LOADED voltage of slightly under 4.8v(unless you have a dead cell), regardless of unloaded voltage.
Losi Will is offline   Reply With Quote
Old 01-16-2005, 11:47 PM   #9
so its safe to run my lathe with that pack i build or should i take a cell out?
Old 01-16-2005, 11:55 PM   #10
I think either way will technically work. If you take it out, you will probably be underpowered, but you won't damage anything. I say stick with 4. A NiCd cell is 1.2V when in use, just one of the constants in everyday life.
Liko is offline   Reply With Quote
Soldering Tips\Wire Type? LosiSuperTruck Electric On-Road 9 09-04-2005 05:28 PM
batterys! kh15 Electric On-Road 19 01-22-2005 02:32 PM
Electrically&Soldering challenged ISO 3-wire ESC & connectors Q and Tips&Tricks Tom G Electric On-Road 4 06-26-2004 09:37 PM
Anyone know where to buy "26 Awg, 22 Stranded Wire" or typical antenna wire? Thanks Shrub Electric On-Road 9 04-16-2004 05:57 PM
Soldering the red wire drx Rookie Zone 5 03-13-2004 04:13 PM
