Old 06-25-2002, 08:13 AM   #16
TPhalen's Avatar
R/C Tech Charter Subscriber
I keep hearing this Tribo stuff....where do you get it at??? I normally don't run comm drops because of the extra maintenance it requires but, since I'm rebuilding the motor every run anyways.....
How much is it???
acloco: ONLY 12 degrees??? heh heh Wow. That's REALLY low. You should be getting alot more than 2 runs on that motor with that low of timing!!! (I would think). We run about 24. Lots o' power!!!! Motor just keeps pulling and pulling. and we are on a pretty small track!!! Good call on the tension of the spring...forgot about that part....
Also. When spraying out the motor, be a bit careful not to douse the brushes with spray. The spray dries quick and removes alot of grit and grime. It will also dry out the brushes (if you are re-using them), removing the natural lubricants in the brushes.
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 06-25-2002, 08:18 AM   #17
stormperson's Avatar
Send a message via AIM to stormperson
so remove the brushes before spraying? and clean them off with a dry paper towel or something?
stormperson is offline   Reply With Quote
Old 06-25-2002, 08:20 AM   #18
TPhalen's Avatar
Just pull them out of the brush hoods.
If you are gonna re-use them, use a comm brush. The best ones are the fiberglass comm brushes. Just be careful...the fiberglass can break and it's a b*tch to see, and if you get it stuck in your skin it's VERY hard to see. I suggest using it over a trash can. But they work the best....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-25-2002, 08:47 AM   #19
rcruv's Avatar
TP - You can get Tribo here.
http://bigjimracing.topcities.com/
rcruv is offline   Reply With Quote
Old 06-25-2002, 08:57 AM   #20
TPhalen's Avatar
8.95 and ounce....might have to try some.....
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-25-2002, 10:45 AM   #21
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Tony I am surprised you have not heard of it. From what I was told Mike likes it alot. I can hardly keep it on the shelf.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 06-25-2002, 11:11 AM   #22
TPhalen's Avatar
Nope....Mike hasn't mentioned anything!!!! So THAT'S the Reedy secret!!!!
Do you have any in stock now???
Tony Phalen
RCDriver.com
CompetitionX.com
Old 06-25-2002, 11:33 AM   #23
How do the magnets in the Orion Core Touring (G12) compare to those of the Reedy Ti (C4)?
James Nguyen is offline   Reply With Quote
Old 06-25-2002, 02:02 PM   #24
Super Moderator
Kraig's Avatar
Tony, yes they are in stock.
Old 06-25-2002, 10:22 PM   #25
Tony,
Yep...12 degrees. If you need to run more timing....go to a lower wind...hehe
IMHO..if you need more than 12-16....that is kind of the point where you are balancing replacing armatures every couple of months or the arm lasting the season.
But...if you are running in a 10 turn limit....than crank it up by all means.
One more item that you might try....use a Trinity 4383 on the positive and an Reedy 729 on the negative. Replace the 4383 after every three runs. The Quasar brush provides the lubricant and the 4383 delivers the power.
acloco is offline   Reply With Quote
Old 06-25-2002, 11:25 PM   #26
shrekair's Avatar
Trader Rating: 9 (91%+)
i believe the core/peak c12 magnets are stronger
shrekair is offline   Reply With Quote
Old 06-26-2002, 08:43 AM   #27
TPhalen's Avatar
Well, we are running 8x1's and 8x2 (sometimes a 7x2) with 24 degrees. Man these things are fast. Love that speed.
But, when you race at the SoCal Worlds EVERY weekend, you need that power....
Tony Phalen
RCDriver.com
CompetitionX.com
