Like Tree33Likes
Sweep F1 tyres.
Old 03-19-2013, 08:07 PM
  #31
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by addicted2blue View Post
Do they need the rubber type wheels or the foam type wheels?
Tamiya Rubber rims are supposed to be the right ones. The new pic on the website shows where the rim beds into the groove in the tire and the tuning tip shows trimming the inner lip inside the tire as a tuning aid.
For putting the foam insert on the tire: They want you to turn the tire inside out, then apply the foam to the tire in the and turn it back the right way out. The foam has a sticky side on it and it's peel and stick.
liljohn1064 is offline
Old 03-19-2013, 09:21 PM
  #32
Odin544's Avatar
Trader Rating: 93 (100%+)
Thats a nice touch on the foams. I always had issues with the pit shimizu foams. Either they would have a hard spot from gluing them or they would bunch up if you didn't glue them
Definitely have to try these out.
Odin544 is offline
Old 03-19-2013, 11:59 PM
  #33
Dan
Dan's Avatar
Trader Rating: 64 (100%+)
How do these tires compare to the popular Shimizu tires on outdoor asphalt?
Dan is offline
Old 03-20-2013, 05:48 AM
  #34
Check out the video down at the bottom of the web page on the F1 Tire section. That car is running on indoor asphalt and is absolutely on rails. Follow their guide for recommendation and try a set.
Old 03-20-2013, 12:11 PM
  #35
Dan
Dan's Avatar
That does not answer my original question.
Dan is offline
Old 03-20-2013, 01:41 PM
  #36
Oh Mr. Sweep USA, we need you!
These just went on sale this week, so, no clue other than the video.
Old 03-20-2013, 08:43 PM
  #37
Nuno Gancho's Avatar
USA Sweep, do the tires fit FGX wheels.
Nuno Gancho is offline
Old 03-21-2013, 02:35 AM
  #38
FGX rims fit the same rubber tires made for the F201 and F104 rubber tire rim as we can see from the pics posted...and as I stated earlier
InspGadgt is offline
Old 03-21-2013, 05:00 AM
  #39
Dragobrat's Avatar
Default in stock anywhere?
Hi. Are these new sweep f1 tires in stock anywhere? The sweep website is now already showing no availability..
Dragobrat is offline
Old 03-21-2013, 07:20 AM
  #40
Company Representative
SweepRacingUSA's Avatar
Hello
for the US, we will have regular batch of tires with improved inserts very soon.
Thank you, have a good day.
SweepRacingUSA is offline
Old 03-22-2013, 01:29 PM
  #41
These tires fit perfectly on Tamiya rubber rims.
Old 03-22-2013, 02:36 PM
  #42
Which shops are carrying these tires?
Old 03-22-2013, 03:18 PM
  #43
I ordered mine directly off the Sweep website.
Old 03-22-2013, 04:14 PM
  #44
240Z's Avatar
tqracing.com
240Z is offline
Old 03-22-2013, 05:25 PM
  #45
nrtv20's Avatar
Originally Posted by 240Z View Post
tqracing.com
Only 12.99 a pair, thats pretty good.
nrtv20 is offline
