Like Tree15Likes
Sweep F1 tyres.
Old 06-05-2018, 05:52 PM
  #271
Adamska27's Avatar
Not 642224 - it doesn't work, THE INSERTS ARE TOO SOFT IN THE GROOVED TYRES FOR MOST SURFACES
Adamska27 is offline
Old 06-06-2018, 03:21 AM
  #272
I think it would be wise to make a new batch of tyres which are the same diameter, offset and width as the pit shimizu. People would be put off immediately when they have to reset their car to suit your tyres dimensions.
Of course the tyres have a long way to go, to match pit shimizu on asphalt anyway. Maybe carpet is different?
ixlr8nz is offline
Old 06-07-2018, 06:26 AM
  #273
Company Representative
SweepRacingUSA's Avatar
Inserts are same for all of our tires.I think 28 should work better.
We are consistently working on next tires. but the V4 works good on half of the globe but need more work on the other half.
SweepRacingUSA is offline
Old 12-03-2018, 06:53 PM
  #274
I知 trying out front tires, and wanted to know which tire you recommend. The track is technical, low to medium grip asphalt...I知 looking for more steering. I知 not sure if I should try grooved or slick or 24 or 28.
thanks
photeckk is offline
Old 12-05-2018, 06:15 AM
  #275
thanks
28 slick.
https://www.sweepracingusa.com/10th-...ium_p_717.html
https://www.sweepracingusa.com/10th-...ium_p_720.html
Old 07-13-2019, 06:04 PM
  #276
5th wheel's Avatar
Ok so I ordered some tires for my F1 I got E24 rears and 24 and 28 fronts. All grooved.tires hope they work.here in Florida at valkaria. I got the grooeved tires because we blow the track off but it’s still dusty with little bits of sand on it the blower can’t get it all. Track temperature is around 120 to 130 degrees and they also spray the track too.so hoping the new tires will work on that asphalt. ?
5th wheel is offline
Old 07-30-2019, 05:41 PM
  #277
5th wheel's Avatar
The E 24 rear grooved did great still got some runs left on them.the front 24 soft not so good on asphalt the 28 fronts not to bad but can only get about 4 10 minuets runs out of it .
Old 08-02-2019, 06:55 PM
  #278
5th wheel's Avatar
Over all I think the tires did very good on asphalt.wiil get some more
Old 08-26-2019, 05:33 PM
  #279
5th wheel's Avatar
What traction sauce is good on asphalt F1 hot track in Florida
Old 08-28-2019, 06:48 AM
  #280
Our X3
https://www.sweepracingusa.com/Sweep...uce_p_120.html
Old 08-28-2019, 05:49 PM
  #281
5th wheel's Avatar
Originally Posted by SweepRacingUSA View Post
ok thank you. I never use sauce so I don稚 know much about it.
Old 09-08-2019, 05:53 PM
  #282
5th wheel's Avatar
Just ordered some more F1 tires going to try out the slicks.the groove did pretty good at my track
Old 09-15-2019, 05:30 PM
  #283
5th wheel's Avatar
In my last order there were no tire stickers in the bag ?
Old 09-16-2019, 03:52 PM
  #284
we ran out of it for awhile. got them back. please email us your order#. we will mail some out to you.
thanks
Old 09-17-2019, 06:26 PM
  #285
5th wheel's Avatar
thanks
thank you order #. S19697
Melbourne Florida
