Old 06-04-2014, 01:36 PM   #181
Suspended
Smile
Very good idea !!! I hate gluing........
Originally Posted by SweepRacingUSA View Post
We are under testings for pre-glued set. once we settle with compounds combination. we may introduce 4 tires per pack set.
bertrandsv87 is offline   Reply With Quote
Old 06-04-2014, 01:46 PM   #182
Zedsispeho's Avatar
Originally Posted by monkeyracing.cz View Post
Do you still recommend to trim the inner gluing lips off on new V2 rear tires please? Thanks.
No this is not necessary
3 Racing FGX, 21.5T sensored + Esc Hobbyking 80A Turbo.
Team Saxo F1-180 21.5T sensored + Esc Hobbyking 80A Turbo.
Yokomo YRF001 13.5T sensored + Esc Hobbywing 80A Turbo.
Zedsispeho is offline   Reply With Quote
Old 06-04-2014, 04:09 PM   #183
That would be great for a spec tire for big races..provided they work well. Having to glue up spec tires at the check in table is a pia. They would need to work well on carpet without having to glue the sidewalls of the tire to stiffen them up.
Old 06-10-2014, 09:08 AM   #184
Company Representative
SweepRacingUSA's Avatar
+1 Thanks
+1 Thanks
Yes, we will find the correct ways to do it right. Thanks
SweepRacingUSA is offline   Reply With Quote
Old 06-10-2014, 11:52 AM   #185
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Is there still a trade in for the very first generation of the F1 tire? I still have 2 full sets, one unglued for sure.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now   Reply With Quote
Old 06-18-2014, 10:46 AM   #186
What width do I get when I take the sweep (F104) rims on a F103 chassis…???
single cab is offline   Reply With Quote
Old 06-18-2014, 01:19 PM   #187
A narrow rear ended F103 with tall tires! The rear axle for the F103 and F104 is the same width, but the pod side plates don't go as high on the F103 as the F104 so the rear will sit high. The F103 is 20mm wider in front, but you can bolt the F104 front end on it to get it back to a shorter wheelbase 180mm trackwidth car.
Old 06-18-2014, 05:25 PM   #188
Hmm… So the rear hub are forming the same width and the front of the F104 is 20mm narrower than the F103 . If I mount the rear the F104 rim then I get a width of 180mm and mount the F103 200mm . But if I mount the F104 rims on the F103 , I get a width of 200mm . So the two are in the same offset only the rear are different… Only with a narrow axis I can fix it to 180mm.
Have I understood correctly..?
Old 06-18-2014, 07:54 PM   #189
To make it 200mm with F104 rims you would indeed need a wider axle or rims for the rear with greater offset.
Old 06-19-2014, 12:46 PM   #190
The problem is , I have a F103RS and would like race with them but our race rules say 190mm width and sweep rims… I think I need to buy a new chassis maybe a SpeedPassion SP-1...
Old 06-19-2014, 02:51 PM   #191
SP-1 is a good choice
Old 06-19-2014, 03:28 PM   #192
Thank's
…normaly I use Tamiya Cars but that was once.
Old 06-23-2014, 03:33 PM   #193
Old 07-22-2014, 09:15 AM   #194
Alex Trinko's Avatar
Hello
Who knows which rims (Sakura) fit with Sweep tires?
MODELLSPORT TRINKO
Alex Trinko is offline   Reply With Quote
Old 07-22-2014, 09:48 AM   #195
Zedsispeho's Avatar
Originally Posted by Alex Trinko View Post
Hello
Hello
There are no rims on FGX (sakura) that can be used with Sweep tires
Sweep Racing Tires 1/10th Sedan thread SweepRacingUSA Electric On-Road 755 09-10-2017 10:36 AM
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
*** MASSIVE RC CLEAROUT *** spar9368 Australia For Sale/Trade 13 11-02-2010 06:14 AM
Tamiya Asia Cup 2010 CheeYong Malaysian R/C Racers 227 06-23-2010 03:08 AM
