Old 10-14-2013, 04:04 PM   #166
Ph3nyx's Avatar
we did a video review of the tires here for rcf1.fr : http://www.youtube.com/watch?feature=player_embedded&v=o70Yd7bvoLs
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 10-27-2013, 09:10 AM   #167
NutDriver's Avatar
Trader Rating: 19 (100%+)
@SweepRacingUSA,
Is there an easy way to tell V1 from V2 if we happen across them in our lhs?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 10-27-2013, 11:16 AM   #168
macavant's Avatar
Trader Rating: 64 (100%+)
Received the replacement tires from SweepUSA this week - thanks SweepRacingUSA!
Getting the new set of V2s was a painless process and with really fast response.
Both F&R V2 I received came with grey inserts and the tactile feel of the tires feel different from V1. Insert and tire install are the same (from V1). Will update as I run them - planned track visit this week.
@NutDriver; the packaging for the V2 I received were marked as "Rear SOFT V2" and "FR MED V2".
likes the oldskool RC action...
F201☆F104WGP☆M01.M05.YR4MSe.TA05.XV-01Pro.ABC_Genetic(Exotek)☆microRS4-Motek☆TA02SW☆WR02.CC-01.G6-01.SandScorcher☆TRF201☆TRF417X.TRF101.TRF101W
macavant is offline   Reply With Quote
Old 10-27-2013, 01:50 PM   #169
NutDriver's Avatar
Thanks!
USVTA member #111
Old 10-30-2013, 07:03 PM   #170
Csaari77's Avatar
Trader Rating: 34 (100%+)
Can anyone give some input on the V2 tires on carpet? How do they compare with the Pits on low to med traction carpet?
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 10-30-2013, 07:11 PM   #171
Jerry P's Avatar
Trader Rating: 44 (100%+)
I plan to run the tires on my vbc f1 over the weekend. I picked up super soft and soft rears, I also picked up soft and medium fronts. I'll check back I. After they have a few runs.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 11-08-2013, 01:24 PM   #172
bhambrent's Avatar
Any feedback yet?
Csaari77 and I are try to get the F1 class going at our Carpet track, Any info on what work best on medium to high grip carpet track would be great.
Thxs,
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 11-08-2013, 04:45 PM   #173
alloyslash's Avatar
Definatly interested in their performance on carpet!
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 11-08-2013, 07:37 PM   #174
mtveten's Avatar
Trader Rating: 27 (100%+)
Avoid them, the v2 tires are better than their 1st efford b ut they are still far from a raceable tire in most conditions and when they do work they are not as good as the shimuza rubbers. If the plan is to have a cheap spec tires the pardus tires make a better control spec than these.
mtveten is offline   Reply With Quote
Old 11-09-2013, 04:28 PM   #175
Typeone's Avatar
Trader Rating: 30 (100%+)
Can u use the Sweep tires on the exotek wheels I know there intended for pits but does the Sweeps fit without modification?? Please respond before I purchase and what tire combo for outdoor asphalt preped track with temps dropping for the winter. Right now I run pits 571/572's
TRF101/Tamiya F104-V2/ TRF Tamiya 417/ Smokem FX chassis & V7 conversion/ Speed Passion/ Sweep Racing/ Futaba/ SMC
Typeone is offline   Reply With Quote
Old 11-18-2013, 06:31 AM   #176
Jerry P's Avatar
I finally got around to running my F1 for the first time. I ran a box stock VBC flash with the kit setup. The front end was really stiff so i'll be working on that in the next few weeks.
First day of running i put in 10 runs on Sweep Soft front and rear tires. The tires held up very well. I was putting full compound on the rear and i little less than half on the fronts. The inserts that come with the tire felt firm and full once mounted. They were on F104 foam wheels. The next set i'm mounting will be on exotek wheels. The tires held up nicely and the car wasnt doing anything strange. No traction roll issues either and we have a straight away that has a hard right at the end of it.
Jerry P
Old 11-19-2013, 04:55 PM   #177
Jerry P's Avatar
I'm going to check out the Sweep tires on Exotek wheels. I've been too lazy to check them but I'll have time to try them tomorrow.
Jerry P
Old 05-08-2014, 09:37 AM   #178
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Any new information or test results?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 05-08-2014, 03:46 PM   #179
Company Representative
SweepRacingUSA's Avatar
We are under testings for pre-glued set. once we settle with compounds combination. we may introduce 4 tires per pack set.
SweepRacingUSA is offline   Reply With Quote
Old 06-04-2014, 09:29 AM   #180
monkeyracing.cz's Avatar
Do you still recommend to trim the inner gluing lips off on new V2 rear tires please? Thanks.
www.monkeyracing.cz | www.rallybrno.cz
monkeyracing.cz is offline   Reply With Quote
Sweep Racing Tires 1/10th Sedan thread SweepRacingUSA Electric On-Road 755 09-10-2017 10:36 AM
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
*** MASSIVE RC CLEAROUT *** spar9368 Australia For Sale/Trade 13 11-02-2010 06:14 AM
Tamiya Asia Cup 2010 CheeYong Malaysian R/C Racers 227 06-23-2010 03:08 AM
