Old 01-22-2005, 02:57 AM   #331
RCknight's Avatar
Default It's sad that car never had more....
testing and development done. I guess I was right by the vibe of the artical it had potential.
Impactplayr...
I didn't know it had that, man, I may have to consider the new X-ray. Although, I do like molded carbon on my cars.
RCknight is offline   Reply With Quote
Old 01-22-2005, 03:06 AM   #332
RCknight's Avatar
Default One thing...
I've never liked having my servo or motor hanging out over the chassis. It's not protected.
Another reason why I really like that HPI protochassis.
Old 01-22-2005, 03:08 AM   #333
johnbull's Avatar
Default Re: The one thing I never see on a belted cars are...
Originally posted by RCknight
two piece aluminum bulk heads? One that you can get the diffs out of easy. That's one thing I don't like about the belted car designs I've seen. I have never see it done and I don't see why it couldn't be done. Have it screw in from the top, 4 screws, swing it up, over and it's out. An external diff adjustment would be great.
Try Schumacher. hey have always laid the diffs from the top.
The old Yokomos were the same as were plenty of others.
I agree with you that it seems so much more logical.
johnbull is offline   Reply With Quote
Old 01-22-2005, 06:33 AM   #334
RDX_Charade's Avatar
Default (RD)X-ray
Hi racers,
Looks like many that many companies trust the belt way the more right way. Because a shaft drive has some more dislikes in car performance. Left to right/right to left balance.
That's why I race the Corally RDX. It drives awesome. But will this really be the new X-ray.
http://www.rczone.net/modules.php?na...rticle&sid=566
So not the car in the earlier picture. I must say that I don't really like it!!
CU
RDX_Charade is offline   Reply With Quote
Old 01-22-2005, 08:48 AM   #335
Default Re: (RD)X-ray
Originally posted by RDX_Charade
Hi racers,
CU
That's ridiculous the way you write " (RD)X-ray " lolololol,.......What do you mean backside??????lololol
Imo, i rather think Sir XRAY and Sir Corally don't play in the same pitch and with the same brain....lololol....Better you change your car before the RDX changes you in a " Rat Ditto Xerox "
Jonas is offline   Reply With Quote
Old 01-22-2005, 09:42 AM   #336
I'm sorry. Car looks nice and clean on the 1st look, but I really prefer my RDX. No negative feelings to other cars.
Old 01-22-2005, 10:33 AM   #337
TRF415boy's Avatar
Default Re: Re: (RD)X-ray
True, Corally seems to be always one step ahead of X-Ray. Remember the first T1 was basically a rebadged C4.1, now they're coming out with a copy of the RDX (which is a copy of the 415, which is a copy of the MY-02, which is a copy of the YM34T, etc...). Now Mr Corally must be right pissed off...
TRF415boy is offline   Reply With Quote
Old 01-22-2005, 11:00 AM   #338
The designs will always look similar, the differences are in teh execution... and that is where X-ray will always shine, the cars just fall together, and simply preform..... not to mention the backwards compatability.... what other manufacturers cars can use the suspension parts from older kits as tuning options????
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-22-2005, 11:10 AM   #339
Anders Myrberg's Avatar
"Everybody has the right to be stupid....... STOP abusing your priviledge!!!!!
It is better to keep you mouth shut and have people think you are an idiot than to open your mouth and remove all doubt........"
This is funny!
Anders Myrberg is offline   Reply With Quote
Old 01-22-2005, 02:02 PM   #340
MartinSorlie's Avatar
I don't think Mr. Constant Paul cares a lot, and Juraj Hudy does his job. These cars of course have they're similarities, but they are by no means the same cars...
It's like twins, they might look the same, but oh boy can they be different to handle... eh....
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 01-22-2005, 02:16 PM   #341
Old 01-22-2005, 02:24 PM   #342
Twin sisters then
TLR - Spektrum
Old 01-22-2005, 02:32 PM   #343
rayhuang's Avatar
A couple quick issues. The Xrays on carpet I think tend to rub the chassis sides a LOT-even when narrowed up (aftermarket chassis) so a very narrow design will help there. Oh-raising the car up to say 5mm is not an option in my book.
And sadly-I dnt think Xray will shorten the shocks or ower the shock towers anymore. I say this because they would then antiquate there very fine line of shock springs-which are longer than associated, Losi, etc. But maybe with some ingenuity-they could make a shorter body that can still use the same springs.
Just my thoughts on things I have read.
Ray
Old 01-22-2005, 03:02 PM   #344
Thraex's Avatar
Let's not forget that Xray is A sort of "The new kid on the block"
Where companies like Tamiya, Corally, Yokomo, HPI and some more have many years (and some even decades) experience.
Xray hasn't, they just stared, and they already are on the top.
If your saying Xray isn't inovative enough and copies things from others, I think you're wrong.
First thing, everyone copies, sometimes they don't even notice it.
It's a part of the business, and not only this... every business.
Second, there aren't many options you can choose from, for example, take A look at all those shafty's, they all look the same, but there just aren't so many layouts you can choose from.
I think Xray stands out from the crowd, it has so easy to tune and work on.
For example, you can adjust the rear toe angle by adding or removing A caster clip.
If you take A look at A 415, Pro 4, CGM and many more, you have to take the hingpin holder and replace it with another one (every degree has it's own holder).
Xray has always done there homework, and (I hope) it won't be different this time
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 01-22-2005, 03:59 PM   #345
I have read conflicting comments on this forum. Is Feburary still a realistic release date for the new Xray? I would have to say NO!! It would be nice to have for the SnowBirds........
Ginsu is offline   Reply With Quote
Prototype chassis impdog Oval, Larger Scales and More 1 12-25-2007 03:51 PM
Prototype Xray 007 Shaft Drive Barry White Electric On-Road 38 03-11-2007 07:08 AM
New .12 JP prototype ... Sow&Steady Onroad Nitro Engine Zone 0 11-13-2005 05:12 PM
Losi 4wd prototype + BJ4 prototype at Worlds cartmen34 Electric Off-Road 32 08-24-2005 09:13 PM
Bmi Tc4 Prototype Test Car protc3 R/C Items: For Sale/Trade 12 01-26-2005 06:02 PM
