Help out RS4 ? Sprint ? & Kyosho on-road >
Old 02-27-2012, 06:39 PM
Trader Rating: 108 (99%+)
Default Help out RS4 ? Sprint ? & Kyosho on-road
Need help to find out what these 2 cars, thanks
HPI 4WD but it's front belt and rear just gear box, cant find out what model is this
Kyosho GT ??? too old can not find out the model name lol
THANKS FOR HELPING !!
Yin1235 is offline
Old 02-27-2012, 06:50 PM
R/C Tech Elite Member
RCBuddha's Avatar
Trader Rating: 40 (100%+)
First one is the original HPI RS4; not sure of the second one.
RCBuddha is offline
Old 02-27-2012, 06:51 PM
I check all the RS4 are front & rear both belt , this one rear only gear box.
so it's old one ?
Yin1235 is offline
Old 02-27-2012, 06:53 PM
RCBuddha's Avatar
so it's old one ?
The original came with a gearbox in the rear. They switched to two belts shortly after the car came out, and became standard on the RS4 Pro.
RCBuddha is offline
Old 02-27-2012, 07:03 PM
thanks for the info, so Can i remove the front belt and just use rear gear box make drift car? that will be cool eh ? just like the real car lol.
Yin1235 is offline
Old 02-28-2012, 04:16 PM
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Second one is a Kyosho GP Spider. Were out from the early to late 90's... still have mine
Ed Anderson is offline
Old 02-29-2012, 01:16 AM
You can try it, but it will be only good for donuts. There are good reasons all r/c drift cars are 4wd.
terry.sc is offline
Old 04-04-2012, 02:53 AM
If you run the RS4 - you will most likely strip the rear gears and they are NLA.
Good collector's item.
angus is offline
