Old 01-13-2005, 12:08 PM   #1
Default Motor Questions????
When running a mod, 19t, stock motor what capacitors and diodes and how many should i use and how should i mount them.
SPC Racer is offline   Reply With Quote
Old 01-13-2005, 01:00 PM   #2
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
In most all cases, it takes 3 diods.....however, most motors have them pre-mounted and you shouldn't have to worry.
Mount them neg to screw tab.....pos to screw tab.....pos to neg.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 01-13-2005, 02:26 PM   #3
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Default Re: Motor Questions????
depends on motor, go to their website and do a search...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 01-13-2005, 02:34 PM   #4
mo
mo's Avatar
That would be 3 capacitors, not diodes.
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-13-2005, 02:36 PM   #5
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
You mean 3 capacitors.
That is the typical configuration though.
Capacitors
- Positive to Negative
- Positive to Screw Tab (or can)
- Negative to Screw Tab (or can)
Diodes
- Positive to Negative (be sure you have the + in the right place.)
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 01-13-2005, 03:17 PM   #6
where can you get the capacitors and diodes and what ones are they or how do i tell i have the right ones.
Old 01-13-2005, 06:55 PM   #7
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
They should come with the motor or your ESC. Also be sure to read up on them , some dont like certain ones.
Artificial-I is offline   Reply With Quote
Old 01-13-2005, 09:25 PM   #8
Speedie's Avatar
Scott Jason should have capacitors at the shop. The diode is the shrink wrapped thing attached to your GTX.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Motor questions... bvoltz Rookie Zone 3 03-10-2006 04:56 PM
3 questions about Motor,batterie and motor lathe Rasmus TbEvo IV Electric On-Road 8 02-18-2006 01:30 PM
Motor Questions SPC Racer Electric On-Road 1 07-30-2005 11:48 PM
Motor questions RoGuE_BULL Rookie Zone 3 02-12-2005 09:36 AM
motor questions stoopidbstrd Electric On-Road 12 03-10-2003 11:19 PM
