Old 02-18-2012, 05:09 AM   #1
Default hobbywing xerun 1s esc advise
trying to set this esc up for 1/12 onroad can i get some advise. new to electric. most people here in Md uses tekin or lrp so it hard get help setting it up
bigtee is offline   Reply With Quote
Old 02-18-2012, 05:48 AM   #2
Hi mate have a look here
http://www.rctech.net/forum/electric...ings-only.html
All so here
http://www.rctech.net/forum/electric...tware-413.html
but you need to start 30 pages back at least to be able to follow the thread.
big paul is offline   Reply With Quote
Old 02-18-2012, 10:30 AM   #3
Trader Rating: 217 (100%+)
So why would you buy something that nobody else there runs? Now you have no help with set-up or gearing!!!
Andy Koback is offline   Reply With Quote
Old 02-18-2012, 11:15 AM   #4
iVTEC4LIFE's Avatar
Uh... Could it be that Tekin and LRP systems run around and above $300???? Hobbywing runs $150ish.... Seems pretty straight forward to me....
iVTEC4LIFE is offline   Reply With Quote
Old 02-18-2012, 12:56 PM   #5
But...if you can't get it to perform, what good is a $150 speedo?
Used Tekins go from $100-$150, even for a Pro series. Best bet!!!
Old 02-22-2012, 11:14 AM   #6
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
The xerun's are one awesome esc. 10X smoother than a tekin, that is why you would go with that over another esc. Should be a simple task to set it up. I run 3 of these esc's and have had 0 issues and are BUTTER smooth.
Noah Mattocks
ovalracer1m is offline   Reply With Quote
Old 02-22-2012, 02:51 PM   #7
Trader Rating: 67 (100%+)
In my current class there are two of us running Xerun System and the rest Tekin and Mamba. They have no advantage in their systems.
nutz4rcyktw is offline   Reply With Quote
Old 02-22-2012, 03:33 PM   #8
Hi Big Tee,
You can't go wrong with the 1s unit. Affordable and very fast and they are in stock. Our drivers have place VERY well in National competition with the 120A, 1s unit.
Get the unit and program box, download Hobbywing 1.64 from the www.teamcrc.com site and "upgrade" the software to "930stock". Be sure to turn OFF the voltage protection while on the laptop.
Of course, if you are running "blinky" no timing mode, upgrade to V3_508_No_TIMING software. Again be sure to DISABLE voltage protection while hooked to the laptop.
The world of timing and boost is NOT easy, many variables and adjustments that if done incorrectly, can burn a speedo or motor. You will need to carefully "play" with the settings. Always start with the motor timing near minimum and "creep" up the timing on the motor.
Formula to kill a motor?? Lots of motor timing and speedo timing = cooked brushless.
Have fun.
CRC
Team CRC is offline   Reply With Quote
1/10 electric Offroad racing at Keilor rc1b4 Australian Racing 12189 10-18-2017 05:13 AM
HOBBYWING TECH SUPPORT INFO COBRARACING Australian Racing 526 09-20-2017 03:19 AM
