Old 02-18-2012, 12:52 AM   #1
Default F1 type Id help please
Wonder if any F1 gp rc guy's could help with an Id on this car.
Trying to find a instruction manual and mfr.
Having issues on the suspension mounting where the shock mounting plate attaches to the rear bulkhead and that front metal one the holes don't line up,And I don't want to mod it any..
carpet car freak
Wait I just spied a mfr mark on the bottom of the fromt spoiler(say's tamiya 1994) will do some more google work but if anyone has an exact I d would be great
http://www.google.com/imgres?q=1994+...gU&tx=46&ty=74
this link shows it as a f103 model but that graph plate is a bit different(it is on wrong will switch it up...thanks anyway ppl
F1 type Id help please-imgp3825a.jpg   F1 type Id help please-imgp3827a.jpg   F1 type Id help please-imgp3826a.jpg   F1 type Id help please-imgp3828a.jpg   F1 type Id help please-imgp3830a.jpg
Last edited by jlcoolio70; 02-18-2012 at 01:09 AM. Reason: Wait I just spied a mfr mark on the bottom of the fromt spoiler(say's tamiya 1994) will do
jlcoolio70 is offline   Reply With Quote
Old 02-18-2012, 01:02 AM   #2
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
thats a F103L,
not sure why the holes dont line up though.
mild seven is offline   Reply With Quote
Old 02-18-2012, 01:25 AM   #3
Taman's Avatar
Trader Rating: 64 (100%+)
Tamiya kit 58148 Rahal-Hogan Lola T94 - if you go to Tamiyaclub.com you can find the car in their reference section and they have the manual.
Toms 84C, Nissan R91CP, Porsche 956, TRF 417 V5.
Taman is offline   Reply With Quote
Old 02-18-2012, 01:35 AM   #4
F103L aka Newman Haas Indy car...technically not an F1 but still...the aluminum shock mount goes on top of the fiberglass piece and the long screws thread into that...that could be why it isn't lining up right.
Old 02-18-2012, 07:17 AM   #5
Body is Rahal Hogan, but the chassis is identical to the Newman Hass F103L, the manual for that can be found here.
Top deck is correct, but it should be underneath the damper mount plate.
The chassis plate, top decks and wheels are unique to the F103L indycars, but everything else is the same as the standard F103 F1 cars.
terry.sc is offline   Reply With Quote
Old 02-18-2012, 01:59 PM   #6
Oh I missed that...your right that is the Rahal Hogan body. As you say the chassis is identical at any rate.
At any rate to get that top deck to line up above the battery take off the aluminum shock mount you have on there and put it on top of the fiberglass top deck. The bends in the aluminum shock mount are pushing back the top deck so the holes won't line up. There was also an optional stand off that you could use to mount the shock to the chassis instead of the aluminum upper piece. Typically I used the stand-off on my 103L's because I didn't like dealing with that aluminum upper piece.
Carcar Ophidian Canadian R/C Scene 12812 Yesterday 11:29 AM
Coral Springs On-Road Track yyhayyim Florida Racing 1646 01-12-2014 07:32 AM
