Old 03-16-2012, 02:25 PM   #16
MrUnlimited's Avatar
http://www.toughracing.com/ has them for several cars.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 03-23-2012, 05:47 AM   #17
daleburr's Avatar
Originally Posted by Chrissy C View Post
I've been followinjg your project Dale, looks good. I have some parts in with Fibre Lyte at the moment, hoping to get the chassis sent off over the weekend, I might post pics of it up on here at some point...depends on how well it goes though
Your right about the power these days, Schumacher are even producing stronger belts for their TC's at the moment to deal with it so that 0.4mm might be exactly what we need!
The belts should be here by Tuesday, i'll let you know how they hook up and feel.
Cheers
Chris
Any sign of the belts yet?
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-23-2012, 05:51 AM   #18
Chrissy C's Avatar
Sorry Dale, been away for a few days...
The belts turned up on Monday so very quick service! As expected they don't feel as 'supple' as the kit belts, but still perfectly useable. If it turns out that they are causing some drag on the drivetrain then out comes the old sanpaper
I'm not at the stage of the project yet where i can hook all the belts up, but running them over a pulley they seemed to sit on there fine.
For the price they are perfect and i think they'll do the job perfectly too.
Thanks again for the link.
Chrissy C is offline   Reply With Quote
Old 03-23-2012, 07:23 AM   #19
daleburr's Avatar
Thanks for the update, sounds like they'll do the job. Still can't believe how cheap they are (about 1 per belt for anyone else reading)!!!
I'll get mine ordered shortly and see how they go.
Team Xray
Old 03-24-2012, 01:55 PM   #20
adanmtxt1's Avatar
It certainly is cool to see some real dimms for belts like those used in RC cars and industrial applications - I always wondered specifically how the tooth was shaped. Thanks all for this interesting discussion.
|Traxxas E-Maxx||Tamiya Super Clod Buster||Team Losi Mini 8ight||Axial SCX10 Wrangler|
adanmtxt1 is offline   Reply With Quote
Old 04-16-2012, 02:51 AM   #21
daleburr's Avatar
Quick update from me. Ordered my belts on Thursday; 9 belts cut to 3mm width came to under 10 (so about 1 per belt, amazing!). And they arrived Saturday morning less than 48 hours later, absoutely fantastic service from these guys.
Very pleased with the belts. They are slightly stiffer than the ones normally found on touring cars, as they're about 0.2mm thicker overall, but the tooth profile looks spot on and I'm sure they will free up with use.
Here's the website for anyone else wanting custom belts (or just strong, cheap belts; these things definitely won't snap):
http://www.beltingonline.com/3mm-htd-timing-belts-4573
These guys are the saviours of the DIY car builder!
Team Xray
Old 04-17-2012, 03:20 AM   #22
Chrissy C's Avatar
Agree with Dale's sentiments - great company!
Dale, what do you think of reducing the width to 2mm? With the extra thickness of these belts could we use that to get a little efficency back?
Old 04-17-2012, 09:34 AM   #23
daleburr's Avatar
It might work, if you could reduce the pulley width as well. If you don't do that the belt will flip over (I tried a narrow belt on wide pulleys once before, it didn't go too well!).
I'd also be concerned about it slipping more as there will be less grip between the pulley and teeth.
So overall I think I'll be more likely to just sand them down to reduce the thickness, although to start with I'll just run them 'as is'. If my prototype car handles crap then it won't be worth spending time making the belts more efficient...
Team Xray
Old 04-17-2012, 11:59 PM   #24
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
This is a fantastic resource. Makes me definitely want to consider some projects in mind.
Dan is offline   Reply With Quote
Tamiya TA05 Touring Sedan kentech Electric On-Road 11403 06-21-2017 04:10 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-21-2015 12:54 AM
