Old 02-15-2012, 11:04 PM   #1
Monteman's Avatar
Trader Rating: 16 (100%+)
Default Spacing a wheel hex
What would the best way be to fill this gap without creating a friction bomb.
This is on my ERBE-gt build and i don't want the wheels to be able to move in and out.
Alternately how can i hold the axle back to here?
Whats going on here is im running a set of HPI hexes on there and it leaves that gap when the axle is seated into the inner bearing. obviously the savage stub axle is shorter.
Used to run this combo, the washer doesnt work with most of my wheels.
Running this now.
But it leaves me with the gap issue. i tried running the hpi flange nut but it leaves the wheel loose as it doesn't drop into the hole like it should as the axial hub fills it.
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 02-16-2012, 01:35 AM   #2
sosidge's Avatar
Shims. Just find a pack with the correct inside diameter. TOP, Yokomo, Tamiya and others do them.
Old 02-16-2012, 02:43 AM   #3
You can make your own shims from popcan aluminum
maleaco is offline   Reply With Quote
Old 02-16-2012, 06:35 PM   #4
Monteman's Avatar
Something along these lines then? Tamyia part # 53646
They don't list a size though. for $8 i would hope they would be adequate.
Old 02-16-2012, 11:36 PM   #5
For the shim nearest the bearing you don't want it to touch the outside bearing race since this is stationary as opposed to the inner bearing race which rotates. So make sure the OD of the shim is less then the OD of the bearing.
calvin is offline   Reply With Quote
Old 02-16-2012, 11:53 PM   #6
Monteman's Avatar
good point thank you. i think i'll just bring the car with me tomorrow to the LHS and see what they have there.
Tamiya mini cooper sipaboy Electric On-Road 29687 Yesterday 04:07 AM
Tamiya TRF416 / TRF416WE / TRF416X academygaz Electric On-Road 10619 01-01-2015 04:36 PM
