Old 02-14-2012, 11:13 PM   #1
Dread Pirate's Avatar
Trader Rating: 15 (100%+)
Default Orion Program Box Adapter (where is it?)
I just bought a Vortex R10 Pro Brushless ESC (#65102) and the Programing Box (65150).
The instructions say to connect them to use the adapter.
No adapter in the Programming Box, no adapter listed on the Orion web site, no adapters listed on the various retail sites.
Anybody got ideas?
"We face each other as God intended. Sportsman-like. No tricks, skill against skill alone." -Fezzik
Dread Pirate is offline   Reply With Quote
Old 02-15-2012, 12:25 AM   #2
Benzaah's Avatar
Trader Rating: 21 (96%+)
Anybody got ideas?
There should be a cord in the program box that connects via a servo plug to the box and sensor wire to the speed controller. If you do not have this then you are in trouble. It should be in the program card box. Mines was. This is what you need. Not the fan obviously.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 02-15-2012, 02:31 AM   #3
lore's Avatar
Send a message via MSN to lore Send a message via Skype™ to lore
Anybody got ideas?
Hi, the cable is what is in the picture but actually come together with the Vortex R10 Pro ESC and not the program card. Check inside the box of the ESC and should be there.
Lorenzo
RB6 / RT6 / ZX6 / SC6
AE12 R5.1 / F104 Exotek / Tamiya Mini 500 Abarth
Orion R10 Pro all the way
lore is offline   Reply With Quote
Old 02-15-2012, 03:23 AM   #4
smith9turbo's Avatar
i don't have this adaptor with my R10pro too.
So, i must use ESC signal wire for connect to my program box instead.
but if someone can tell me that,
what pin of sensor plug of this adaptor is connect to the white wire of servo plug of this adaptor?
i think, i can build it by myself.
smith9turbo is offline   Reply With Quote
Old 02-15-2012, 06:28 AM   #5
Found it! It came with the ESC, not the Program Box.
Thank you!
Old 03-28-2013, 03:50 PM   #6
Does anyone know where you can purchase this adapter? I seem to have misplaced mine that came with the R10 Pro and just got the programming box.
Dial Din is offline   Reply With Quote
Old 03-30-2013, 01:29 PM   #7
In case anyone's looking for one of these, I just found that you can purchase the Orion programming box adapter at Horizonhobby.com, I'd post the link but haven't made enough posts on this forum to do so yet :-\
Here's the part number to search on their site ORI65151
Old 06-15-2013, 09:21 PM   #8
richclo's Avatar
So, i can use the motor sensor wire to plug in to the adapter then to the program box?
richclo is offline   Reply With Quote
Old 06-15-2013, 10:18 PM   #9
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
yes or you can plug in another sensor wire to the extra open sensor port.
Racing4Evo is offline   Reply With Quote
Old 06-15-2013, 10:27 PM   #10
asc6000's Avatar
not can, it is a must, the only way is to use the adapter. Because there are two sensor wire ports on the R10 many of us leave the motor sensor wire as it is and use the second port for the sensor/adapter to the box.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 06-15-2013, 10:34 PM   #11
asc6000's Avatar
I posted these last year in case someone wants to make their own
Ayrton Senna
Old 12-29-2013, 10:26 PM   #12
avs
avs's Avatar
Hi, I just got a R10 1s used, but with no plug. can you re-post the wiring diagram to make my own?
thanks very much.
Tony Shimko
avs is offline   Reply With Quote
Old 12-30-2013, 10:08 AM   #13
avs
avs's Avatar
i found the standard pin usage in the roar rulebook.
Pin #1- ground potential
Pin #2- phase C
Pin #3- phase B
Pin #4- phase A
Pin #5- temp control, 10 k Thermistor referenced to ground potential
Pin #6- + 5.0 volts =/- 10%
so the positive, ground (6,1) are clear, but which pin is used for the signal? #5 makes the most sense.
if someone has one of these, could they verify which pin is the signal? thanks very much.
Tony Shimko
Old 12-31-2015, 05:17 PM   #14
egalsim's Avatar
Trader Rating: 39 (100%+)
Does anyone have the wiring diagram for this adapter? I need to make my own right now.
Associated RC10B6 / Kyosho Optima / Associated Tekno SC8e / Awesomatix A700exl / Serpent Cobra BE 2.1 Rally / Kyosho MP9 Tki3.5 Tekno V4 / Xray Xb4 2017 / Serpent SDX4
egalsim is offline   Reply With Quote
Old 01-01-2016, 08:05 PM   #15
Drew Manzella's Avatar
Trader Rating: 28 (100%+)
Pins 1,5 and 6
Drew Manzella is offline   Reply With Quote
Orion R10 review the big rc Radio and Electronics 1943 09-03-2017 04:40 PM
