HPI Sprint 2 Drift
Old 02-13-2012, 02:42 AM
Default HPI Sprint 2 Drift
I need help. I bought HPI Sprint 2 drift, I think i mess up the esc configuration, I cant control to move forward but i can steer and move on reverse.Please help ..
chibal03 is offline
Old 02-13-2012, 02:48 AM
EskimoGangsta's Avatar
What esc and transmitter you using?
EskimoGangsta is offline
Old 02-13-2012, 02:52 AM
Stock. SC 15WP -esc and HPI SF10W. Thanks man i really need help badly.
chibal03 is offline
Old 02-13-2012, 03:07 AM
Im doing research on that esc, but i believe it's a auto set esc. so its something you changed on the transmitter. and the SF10W is the servo. i need the thing you use to control the car
Old 02-13-2012, 03:10 AM
HPI TF-40, Sorry Im just new in RC World. I really appreciate your help.Thanks a lot.
chibal03 is offline
Old 02-13-2012, 03:14 AM
Here is what i encounter. When i try to reverse and press the throttle it looks like it is breaking and its giving a pulse red light on ESC.
chibal03 is offline
Old 02-13-2012, 03:16 AM
HPI TF-40, Sorry Im just new in RC World. Thanks a lot.
No problem, i happen to have that exact transmitter in my room but not the esc. i gave it away to someone at our track who was running a brushed mini that was having problems with his. i was never going to use it. and what goes around comes around.
one thing to first look at is the "TH.REV" setting is set in the up position, so its on the "N" its located left to the wheel second thing is to have the "TH.TRIM" is set to the neutral position. you set the TH.TRIM to where their is no green or red light on the esc when your not hitting the trigger
Old 02-13-2012, 03:21 AM
I will try that. Any suggestion on what battery will i buy? I got the stock 2000Mah Plazma and it is lasting like 20 -30 mins. Thank you i really appreciate it.
chibal03 is offline
Old 02-13-2012, 03:30 AM
I am a little bit confused. Where is TH.TRIM located. In my remote i got bind, St, TH, D/R , L ST R, L-TH-R,
chibal03 is offline
Old 02-13-2012, 03:35 AM
I'd convert to lipo, much more power and longer battery life
heres a good battery for your situation:
http://www.hobbyking.com/hobbyking/s...arehouse_.html
And here's a charger:
http://www.hobbyking.com/hobbyking/s...idProduct=6478
Old 02-13-2012, 03:37 AM
sorry i miss read my transmitter. long day um the L-TH-R is your TH.TRIM. make sure thats in the center
Old 02-13-2012, 03:39 AM
This will fit on my Sprint 2 drift. I thinke i need soft packs lipo bats. si it can fit on my RC's chasis.
chibal03 is offline
Old 02-13-2012, 03:42 AM
The TH TRIM is on the center and the TH Rev is on the center also? I know the question is a little bit noob. Sorry.. Again Thank you so much. I will try your suggestions and give you a feed back after work. hehehheeh.
chibal03 is offline
Old 02-13-2012, 03:46 AM
My friend has a sprint 2 and he uses that pack exatly
Old 02-13-2012, 03:49 AM
Copy that. Thanks for your help...
chibal03 is offline
