Old 01-11-2005, 06:54 PM   #1
Default TL-01 gear crunching
I have a TL-01 that makes a crunching noise when i accelerate from a rolling start, or all the time when i have tape on the tires for drifting, i think it is on the front gear of the shaft that goes to the front wkeels... its like its not sitting close enough to the other gears
any help would be great
Cheers
robborc is offline   Reply With Quote
Old 01-11-2005, 07:17 PM   #2
PIIHB!'s Avatar
Make sure you are using the correct motor mount screw locations for the pinion you are using.
Or if all else fails....take it apart to actually see if anything is messed up!
PIIHB! is offline   Reply With Quote
Old 01-11-2005, 07:24 PM   #3
would that effect the front of the shaft where it seems to be grinding??
Old 01-11-2005, 07:28 PM   #4
dsrbltoys's Avatar
Check the shaft gear, and make sure the pin is in correctly. Also it is very common to get a small pebble in the gear. As the suspension compresses, it opens up the bottom of the chassis, allowing debri in. You can use tape to help seal it.
dsrbltoys is offline   Reply With Quote
Old 01-31-2005, 07:02 PM   #5
Default still doing it
still crunching, is def the front end, has started to wear away on the cog in the diff, its mainly in reverse and as soon as the tyres start spinning,
any help would be sweet
Old 02-17-2005, 05:43 PM   #6
ended up buying new sets of gears... have to test tonight
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 10:03 PM
R/C Gear FOR SALEPleanty New and some used off road gear DirtRacer Australia For Sale/Trade 1 11-17-2007 03:45 AM
Pinions, Radio Gear and Battery Gear d4_racer Australia For Sale/Trade 9 09-18-2007 02:07 AM
Help super gear and pinion gear jojo RRR Electric On-Road 0 06-18-2007 07:37 PM
mugen 2nd gear housing and derlin gear for sale. aznxlionhrt R/C Items: For Sale/Trade 0 03-27-2003 07:31 PM
