Old 01-11-2005, 03:42 PM   #1
Default Foam vs Rubber....
Ok this isn't really about which is better...
But which is cheaper...
I see guys at the track who run 1/12th and a few who run mod TC having to mess around with truers, and chunked foam tires.
I am curious to try 1/12th but I wonder if messing around with foams is worth the hassle?
MartynD is offline   Reply With Quote
Old 01-11-2005, 03:46 PM   #2
vtl1180ny's Avatar
R/C Tech Charter Subscriber
YES!!!!
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 01-11-2005, 05:34 PM   #3
fatdoggy's Avatar
If you chunk a tire on it's sidwall, imo it's junk. As long as you check your tires after each run and glue any part of the tire that is lifting, you won't have much trouble. Invest in a can of TRC tire glue, if you slice a tire it's works great. Just make sure that your body has rounded edges and has enough clearance from the tires.
In my opinion 12th scale is alot more fun then TC.
Yes you will need to use a truer, but it is definately worth it. Most people will cut some tires for you if you buy them a soda or give them a few bucks.
fatdoggy is offline   Reply With Quote
Old 01-11-2005, 05:42 PM   #4
robk's Avatar
Trader Rating: 22 (100%+)
oh no
Old 01-11-2005, 07:30 PM   #5
seaball's Avatar
Send a message via Yahoo to seaball
oh no
yes! that's awesome. didn't dave arnold address this debate in years past?
oh yeah, bring it all on.
really though, there are existing threads that have all the opinions needed to make a decision here. infact, any thread that continues past a few days will, at some point, gravitate toward this subject/rivalry. i've studied this.
seaball is offline   Reply With Quote
Old 01-11-2005, 07:32 PM   #6
losixxxs's Avatar
i prefer foam
losixxxs is offline   Reply With Quote
Old 01-11-2005, 07:48 PM   #7
tony2's Avatar
what about foam on ashphalt for TCs? i much rather use rubber tires but on most tracks here in aust. the foam tyres are alot faster.
tony2 is offline   Reply With Quote
Old 01-11-2005, 09:01 PM   #8
fatbear's Avatar
Send a message via Yahoo to fatbear
Foam is definately faster on ashfelt and over many years of experience it is also definately CHEAPER.
Team Associated www.teamassociated.com
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
JConcepts www.jconcepts.net
Ace Hobby Distributors www.acehobbyaustralia.com
fatbear is offline   Reply With Quote
Old 01-12-2005, 12:44 AM   #9
adamkerrnz's Avatar
i run foamson ashphalt on my prostock SD here in new zealand. theyre great and do cost less than rubber, even though rubber might last just a bit longer. the rubber tyres i use on my stock TA04 costs way more. also foams on nitro is much better too, rubbers would just get eaten :P
adamkerrnz is offline   Reply With Quote
Old 01-12-2005, 12:54 AM   #10
RCGaryK's Avatar
I run rubber 99% of the time, but just ran Foam Brushless at the Novak race. I went thru 3 sets of foam when I would have gone thru 1-2 sets of rubber tires. Part was my own fault, truing the tires down to 2.20 to start with and by the time they got to 2.13 I couldn't make 4mm ride height anymore. But I also had an issue with the sidewalls chunking, and like Fatdoggy said once they chunk they're junk. Foams are nice because you have an abundance of traction that hides poor setup better and you will generally have the same grip regardless of how many runs are on them, where rubber tires will lose grip and bite as they age. however you don't need to sweat chunking a tire on one run like a foam tire will. Additionally rubber tire driving requires a smoother and more fluid driver. Foams are easy to drive, faster, and more consistent, but more expensive, messier, and overal less fun.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 01-12-2005, 11:34 AM   #11
CypressMidWest's Avatar
Easier to drive, faster, more consistent, sure sounds alot less fun to me LOL!! The cost debate will always continue to rage on. I know that I personally spend way less money running foams than I did running rubber. (disclaimer: Individual results may vary)
Dear GOD Gary, 3 sets?!! I did Cleveland on 2 sets of foams for my TC. A small bead of CA around the mounting bead will prevent the tires from peeling off the rims, you don't have to run it up the sidewall, just right around the edge of the bead.
Some manufacturers' tires are not bonded very well to the rims, but I'm not gonna name names. The Parma tires I've been running have shown NO tendency to peel at all.
Foam tires will hide poor set-up far better than rubbers, as Gary stated, but foams will still show you that your set-up sucks. They show you your set-up is crappy through ACCELERATED TIRE WEAR.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 01-12-2005, 11:40 AM   #12
RCGaryK's Avatar
Yup, 3 sets dude. And all for practically the same reason, sidewall chunking. And I didn't run the car much at all. I had 2 practice runs before qualifying, DNF-ed a few races, 2 practice runs Saturday morning. So all in all I had 11 total runs. The 3rd set is still in good condition, but the 2nd set chunked the sidewall bad in 1 run. I did glue the sidewalls where the foam meets the rim, but the problem was higher on the sidewall. Oh well, I still prefer rubber tire racing mostly because it IS cheaper.
HorizonHobby.Com
Old 01-12-2005, 11:54 AM   #13
JKA
Only if you run spec tires. Even then its very similarly priced.
$30 for a set of CS27s. $28 for a set of foams.
Chunking can be lessed by cleaning the tires between runs. The traction compound (like paragon) when used run after run will take it toll on a foam.
If you run open rubbers you will spend hundreds finding the correct combination of rim/insert/rubber. Then if its outdoors you'll have to have completely different sets for cold, warm, and hot weather.
They both are a blast though!
JKA is offline   Reply With Quote
Old 01-12-2005, 11:58 AM   #14
Skip109's Avatar
11 runs! I'll bet I had 30 runs on one set of Plaid/ dbl pinks for the hole week. I had no problems with chunking. You also said "hides poor setup"I think you have this backwards. At least when I get 10 runs on my foams my lap times wont drop by 1/2 sec. Leave the foam comments to the people that know how to run them.
Skip109 is offline   Reply With Quote
Old 01-12-2005, 12:13 PM   #15
RCGaryK's Avatar
The whole "magic insert serach" thing is such a falicy it isn't even funny. Back when people were still learing how to get things going, yeah that could have cost a lot, but those days are well over. I have 3-4 inserts that I use on both carpet or asphalt and works really well.
Skip, if your lap times are dropping 1/2 second after only 10 runs, your setup is way off. .2 I'll give you, but not 1/2.
HorizonHobby.Com
FOAM TO RUBBER 32819toon Electric On-Road 7 07-22-2008 08:49 PM
foam or rubber? civiceg Electric On-Road 18 04-27-2007 04:59 PM
Foam or Rubber? pokpok Indonesia Racing 12 04-08-2004 11:41 PM
Foam Vs Rubber fastolfart Australian Racing 66 07-09-2003 04:04 PM
foam or rubber Skid Marks Northwest Racers 65 02-27-2003 11:14 PM
