Old 09-24-2012, 05:18 PM   #16
HollywoodRC's Avatar
Cool
Originally Posted by goots View Post
the lowest Ive tried is 800, good rotation but pushes a little on power. 1300 is the most I tried on sprayed asphalt, Very stable and good on power steering. When I tried 2000 oil handling was very bad ie. very loose on power.
This is with a TCX.
rule of thumb, higher the traction heavier the oil and vice versa. Its all about finding out what works for you.
Thanks goots. I have decided on 55wt shock oil in the diff. I also ordered an Associated spring kit. They are same size and you get more choices than the Schumacher. I had trouble finding Schumacher springs. I am running 40wt front and 35wt rear. I also took off the rear sway bar. The car is really starting to handle well.
HollywoodRC is offline   Reply With Quote
Old 09-24-2012, 06:28 PM   #17
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
I would try the HPI black spring set....they are absolutely great to tune a car with.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 09-25-2012, 02:16 PM   #18
Cool Spring Set
I have heard that, but I like looking in my track box and seeing the different color of springs. Makes it easier for me. I also need to get a lighter battery. My 5000mah is a bit heavy. I just have 5 of them so it's easier.
Old 09-29-2012, 04:59 PM   #19
Default MI4CXL
Just got back into on road after 17 years of running off road. lots of fun.
MAIZER MAIZER
maizer is offline   Reply With Quote
Old 10-09-2012, 11:37 PM   #20
Red face Great Start.....then
Well, ran the Schuy this last weekend and She did pretty well with all the changes. Was turning good laps in practice until got bumped into the wall. Done, broke a front A-arm. I notice that the A-arms were graphite, not great for a bumpy low to no bite track. I ordered some short med flex ones, to replace all of them, front and rear. Where, other than Amain, in the states do you guys find Schumacher Mi4CX parts?
Cheers
Old 10-09-2012, 11:43 PM   #21
olhipster1's Avatar
Cheers
Stormerhobbies
Carries Schuie parts
CAUSE and EFFECT
Old 10-10-2012, 02:35 PM   #22
Smile Parts
Stormerhobbies
Thanks, they had the remaining parts I needed.
Old 10-10-2012, 11:15 PM   #23
Cool Diff height?
I found out today that my Diff height was way to low. I had it on the lowest setting and need to raise it to the highest. Also the pivot blocks need to be adjusted to the 0 setting. Slowly I am going to get this car dialed in. Oh yeah, my belt was to tight as well.
Old 10-11-2012, 05:05 AM   #24
nutsisneat's Avatar
Diff can be either low or high, nothing in between.
Everything else is just different belt tension.
BTW: Diff is always low, i have never seen high on a setup sheet
HTH
nutsisneat is offline   Reply With Quote
Old 10-18-2012, 07:02 PM   #25
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Amain hobbies has Schumacher parts too.
Schumacher Mi4cx Pro kit and some other items for sale haidhir Malaysian Forsale-Trade 7 09-19-2011 12:14 PM
Follow the build of my Schumacher Mi4cx cuttingedge Electric On-Road 9 12-29-2010 01:04 AM
