Old 03-02-2012, 12:48 PM   #61
Hallgm's Avatar
Just installed kit but the right rear seems a little sloppy is this normal??
Hallgm is offline   Reply With Quote
Old 03-02-2012, 02:45 PM   #62
texastc's Avatar
I put a .5 mm shim in the left hub and it got rid of the slop.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and Exotek F1UltraX Prototype.
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom
"you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 03-03-2012, 02:32 PM   #63
Norman2's Avatar
Questions??
Hi, Does anyone have any idea of how this conversion wide track is
installed in a Standard F-104. Thanks for any help as I can understand the
front uprights but cannot figure out how it works in the rear axle. I just ordered one and need some help. Regards
Norman2
Norman2 is offline   Reply With Quote
Old 03-03-2012, 03:03 PM   #64
durtbag's Avatar
Norman2
does this pic help?
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 03-03-2012, 03:55 PM   #65
texastc's Avatar
Norman2
You have to have the Pro diff.
Old 03-03-2012, 04:36 PM   #66
durtbag's Avatar
Whoops, my bad. Completly forgot that a standard F-104 has the 103 type diff. So yeah, you will need to buy a pro diff set.
Old 03-03-2012, 04:48 PM   #67
Norman2's Avatar
Hi, Thanks guys, I just ordered the Pro Dif set. Again Thanks
Norman2
Old 03-05-2012, 12:40 AM   #68
the front axles come in 4 pieces,is that two sets of different lengths?
freakyfreakyflo is offline   Reply With Quote
Old 03-05-2012, 12:43 AM   #69
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
yes, two for 190mm and two for 200mm
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 03-05-2012, 12:52 AM   #70
thank you for reply. if the front is 190 or 200,the rear is only 190?
Old 03-05-2012, 12:53 AM   #71
front is 190 or 200. rear is 190. Or 200 if you use the f103 rears.
J-PaP is offline   Reply With Quote
Old 03-05-2012, 12:55 AM   #72
i was planning to use on my 104 on rubber tire so i use 190 front and the rear for 190 all round
Old 03-05-2012, 12:55 AM   #73
R-Sector's Avatar
R-Sector is offline   Reply With Quote
Old 03-06-2012, 03:30 PM   #74
The Big Wig's Avatar
Why oh why people promote cheater cars I will never understand. F1 is for scale fanatics so 180mm is the ONLY way! Speed freaks go race 1/8th or wing slot cars but don't mess up F1!
The Big Wig is offline   Reply With Quote
Old 03-06-2012, 04:08 PM   #75
JamesHealey's Avatar
I agree with the 180mm and 200mm cars being separated as the 200mm cars have an advantage.
205mm and 190mm well that's just being gay.
1/8th Nitro is great btw! it's blooming expensive though.
F1 should be realistic Retro and Modern.. 200mm and 180mm
It's not hard! 1/10 Nitro has 200mm and 220mm...
Serpent 977 Evo | Novarossi Engines | Racing Experience Fuel | Xpert-RC Servos | Xtreme Tyres | Bitty Design Body Shells |
http://answer-rc.com/en/ - Answer RC supported driver.
JamesHealey is offline   Reply With Quote
