Old 02-09-2012, 06:44 AM   #1
Dreaming rc's Avatar
Default on road car pushes
I have a question hope you can help.. My on road car has great straight line speed but in the long sweeping corners its pushing, run indoor carpet ozinite. im running 40wt oit in front shocks and 4mm ground clearance..any input would be great..
Thanks Dell
Team Tamiya : Werks Racing : Proline : Sidewinder Strike :
Dell Paradis
Dreaming rc is offline   Reply With Quote
Old 02-09-2012, 06:56 AM   #2
big_ads's Avatar
Trader Rating: 80 (100%+)
Send a message via MSN to big_ads
Thanks Dell
What kind of car is it? Maybe try a little bit more camber in the front.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Big Head Racing - Dumpers Speed Shop
big_ads is offline   Reply With Quote
Old 02-09-2012, 07:02 AM   #3
Thanks Dell
4mm might be too low..try 5 or 5 1/2..if your running a soft setup & rubber tires
plus the traction compound might be building up under the chassis on the sweeper side...i would try this first before i change anything else
starrx is offline   Reply With Quote
Old 02-09-2012, 09:55 AM   #4
oeoeo327's Avatar
Trader Rating: 74 (100%+)
+1 - I'm willing to bet that the chassis is dragging, resulting in a "pushy" car in the sweeper. Clean the chassis, raise the car by 1mm on all 4 corners, and try driving the car once more - if the push is resolved, you've found the problem. If not, try more static caster and/or camber in the front. You might want to check overall body height as well, since you don't want the front tires to rub the fenders or the front air dam hitting the track. Both situations tend to make the car push, although you'd notice a push caused by an ill-fitting body in virtually every corner.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 02-11-2012, 12:39 PM   #5
Thanks everyone will try that, and let you know..
Dell Paradis
GT8 Class--buggy-based on road electric! snrscion Electric On-Road 3430 Today 12:58 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
Electric Touring / On-Road RC Screaming Wind Manila Racers 32167 05-02-2017 11:20 PM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
