Old 02-08-2012, 07:23 PM   #1
Default Is this the ESC problem?
I just got a RC18t connected everything and set my end points. But, when I drive it, it tends to have a mind of it's own. Throttle stuck on, turns, doesn't move. When it's glitching I lose control of steering until it hits something. Now, I've used two remotes, two receivers and set end points both times I changed them. Same results. Please help!
LST2 E BL, Losi 8ight RX8/2150kv,
TC3 BL, Losi XXXSCT BL
jrowles91 is offline   Reply With Quote
Old 02-08-2012, 08:07 PM   #2
Jerz616's Avatar
Trader Rating: 49 (100%+)
Have you tried using a glitch buster. My tc5 with a savok servo had a little issue like this. I put on a glitch buster and now it's perfect.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 02-08-2012, 08:40 PM   #3
I've not ever even heard of that! Id rather not use another item as there isn't any room to spare but who makes it?
Old 02-09-2012, 12:39 AM   #4
nexxus's Avatar
Trader Rating: 302 (100%+)
Had the same issue with an SC18 a while back, was the battery pack too close to flat, under load the voltage sagged and the receiver cut out. Recharge the battery and retest
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 02-09-2012, 01:34 AM   #5
MrUnlimited's Avatar
Is the esc brushed or brushless and what connectors are you using? Bad connectors can cause interference.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 02-09-2012, 07:47 AM   #6
The battery connectors are stock. they look like mini deans except they are white. The esc is brushed.
Old 02-09-2012, 08:35 AM   #7
mkiiina's Avatar
Trader Rating: 69 (100%+)
What radio and steering servo are you using?
mkiiina is offline   Reply With Quote
Old 02-09-2012, 08:45 AM   #8
Radio was Spektrum DX3 and a Flysky both with different receivers. The servo is a Hitec HS65mg
Old 02-09-2012, 10:36 PM   #9
I think I might have gotten it!! Bad battery... I changed out to a spare 10 scale servo I had and same problem was there, then I thought crap, it's the esc. I remembered I had just bought a 2s lipo for my boys truck that I mini deans on and shoved that on the esc connector. I SEEMED TO WORK! I just did little tests on my work bench, I will mess with it more to ensure I'm not missing something. Thanks for all the input!!!
Hobbywing EZrun 60A ESC problem... tamiya_d1_junky Radio and Electronics 14 10-24-2010 02:18 AM
esc problem work4rc Electric Off-Road 7 04-28-2009 02:36 AM
What is this??? Rebuild Electric On-Road 18 12-22-2006 05:23 AM
JMRCA change touring rule to 4cells! Is this the future? ttso Electric On-Road 214 11-05-2006 12:08 PM
